Can't upload to Pro Trinket ATmega328p 5v 16mh
by deu1 on Fri Mar 29, 2019 8:03 pm
I purchased a Pro Trinket recently and tried to upload the sketch for Andy Doro's NEOMATRIX 8X8 WORD CLOCK. It did not upload and now when I try to upload to the trinket its red led only blinks very quickly 4 times and then turns off. It DOES NOT PULSATE as it is suppose to do in order to upload code. If I press the reset button it just blinks like I described above. The green led stays on. It is a Pro Trinket ATmega328p, 5v, 16mh. The correct board is selected in the Arduino IDE and the correct programmer: USBtinyISP. I also tried to search this forum for help with this, but could not find any posts related to it. I NEED HELP.
Dan Urbauer
deu1
Re: Can't upload to Pro Trinket ATmega328p 5v 16mh
by franklin97355 on Fri Mar 29, 2019 9:59 pm
When you set the preferences to verbose what do you get when you try to compile and upload?
franklin97355
by Deangj on Fri Apr 05, 2019 3:06 pm
I have a similar problem, I have in the past uploaded to this trinket, now I have new computer. The red light blinks appropriately but I get this verbose output...
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/private/var/folders/gg/n6c5t8653xscb9_gm0b5qpxc0000gn/T/AppTranslocation/21E82F82-7814-4001-BCB5-5546E9EAA718/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/deanjohnson/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 020:021
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, https://learn.adafruit.com/usbtinyisp
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: 4 retries during SPI command
avrdude: AVR device initialized and ready to accept instructions
An error occurred while uploading the sketch
Reading | avrdude: 2 retries during SPI command
################################################## | 100% 0.00s
avrdude: Device signature = 0x1e930b (probably t85)
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
avrdude done. Thank you.
Deangj
by franklin97355 on Fri Apr 05, 2019 4:16 pm
Can you post a picture of your Pro Trinket and the connections you have to it?
franklin97355
by Deangj on Mon Apr 08, 2019 12:36 pm
This isn't the original circuit, but I went back to the basics and am trying to Blink the LED. The blue LED, when connected to #1 blinks along with the onboard red LED when I press the button once. During this blinking period I try to upload the Blink code and get the error I reported above. Perhaps I'm forgetting something I used to know. Thanks for taking a look.
trinket basic.jpg (186.32 KiB) Viewed 116 times
Deangj
by deu1 on Wed Apr 10, 2019 3:13 pm
Franklin,
I have finally been able to upload the sketch into the Pro Trinket using a FTDI cable. Much easier to do it with FTDI.
My problem now is that I can not get the RTC to show the correct time. It always shows the time one hour ahead of my time. I purchased the RTC, Pro Trinket, and 8x8 Neopixel LED display from Adafruit. I tried putting "OBSERVE_DST" to 1 rather than 0, but that didn't work. If I disconnect the 8x8 Neopixel LED display from the Pro Trinket and run a sketch called "RTC_READ_TEST" it shows the correct time in the Serial Monitor. I'm trying to build the Word Clock by Andy Doro. Please Help.
Dan
deu1
by franklin97355 on Wed Apr 10, 2019 3:59 pm
If the RTC is running and showing the correct time in the example code but not in the word clock code it must be a code error in there somewhere.
franklin97355
