Pro Trinket 5v - avrdude ERROR
by AntoineGodfather on Sat May 11, 2019 1:35 pm
I just followed the adafruit steps to upload "blink" in my Pro Trinket 5V 16MHz with USBtinyISP.
I installed the adafruit drivers several times, the red led is pulsing in bootloader mode before the upload, i reprogrammed the bootloader several times, i rebooted my computer several times.
But after several attempts, i always get this output message:
Le croquis utilise 930 octets (3%) de l'espace de stockage de programmes. Le maximum est de 28672 octets.
Les variables globales utilisent 9 octets de mémoire dynamique.
C:\Users\Antoine\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\Antoine\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -cusbtiny -Uflash:w:C:\Users\Antoine\AppData\Local\Temp\arduino_build_749762/Blink.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Antoine\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, https://learn.adafruit.com/usbtinyisp
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\Antoine\AppData\Local\Temp\arduino_build_749762/Blink.ino.hex"
avrdude: writing flash (930 bytes):
Writing | ############
avrdude: error: usbtiny_send: libusb0-dll:err [control_msg] sending control message failed, win error: Un périphérique attaché au système ne fonctionne pas correctement.
(expected 128, got -5)
######avrdude: 3 retries during SPI command
###########avrdude: 1 retries during SPI command
#############avrdude: 3 retries during SPI command
# | 100% 4.07s
avrdude: 930 bytes of flash written
avrdude: verifying flash memory against C:\Users\Antoine\AppData\Local\Temp\arduino_build_749762/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\Antoine\AppData\Local\Temp\arduino_build_749762/Blink.ino.hex:
avrdude: input file C:\Users\Antoine\AppData\Local\Temp\arduino_build_749762/Blink.ino.hex contains 930 bytes
avrdude: reading on-chip flash data:
le port série sélectionné
n'existe pas ou votre Arduino n'est pas connectée
Reading | ################################################## | 100% 0.04s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0116
0x97 != 0xa1
avrdude: verification error; content mismatch
avrdude done. Thank you.
Here You Can See the tools configuration for the upload
blink attempt.png (21.38 KiB) Viewed 164 times
Can someone please help me to solve the problem ?
Thank you for reading.
Antoine.
AntoineGodfather
Re: Pro Trinket 5v - avrdude ERROR
by adafruit_support_mike on Tue May 14, 2019 4:18 am
The errors look like you have an intermittent connection between the computer and the Pro Trinket.
Try using a different USB cable and see if that helps. At USB speeds, the cable is a component, and they aren't all made the same. Sometimes you get one that a microcontroller just doesn't like.
by AntoineGodfather on Tue May 14, 2019 7:59 pm
Thank you for your suggestion,
Finally i bought an other pro trinket and a ftdi friend.
After several tests:
*The usb connection of the topic's pro trinket doesn't work, and its ftdi connection works.
*The usb and ftdi connections of the other pro trinket work.
So i think that the problem come from the pro trinket. I forgot to say that i had already tested others usb cables.
Antoine.
AntoineGodfather
by adafruit_support_mike on Tue May 14, 2019 11:55 pm
Post a photo showing the component side of the Pro Trinket whose USB connection doesn't work please, along with any other connections you've made to the board. 800x600 images usually work best.
