circuitpython 4.0.0 on trinket M0 frozenset ?
by terryr on Mon May 20, 2019 10:46 pm
I have a working connection to a Trinket M0 reading a bmp280 sensor just like the example .py code.
Tried to upgrade circuitpython to the 4.0.0 version, now running the bmp280 example, I get an error:
code.py output:
  File "code.py", line 12, in <module>
  File "adafruit_bmp280.py", line 65, in <module>
NameError: name 'frozenset' is not defined
Yes, this is with the 4.0 lib bundle.
Any clues?
terryr
Re: circuitpython 4.0.0 on trinket M0 frozenset ?
by franklin97355 on Tue May 21, 2019 12:58 am
Not sure why it was working before but it is disabled for non-express boards. https://circuitpython.readthedocs.io/en/latest/docs/library/builtins.html?highlight=frozenset#frozenset
franklin97355
by terryr on Tue May 21, 2019 1:17 pm
From the outside that seems to be a cryptic deviation but I should have read the docs more carefully
Thanks for the quick response, I can stop tearing out my hair.
terryr
by MakerMelissa on Tue May 21, 2019 10:12 pm
Hi, I have published a fix for this. The update should be available as part of the bundle when it is released tomorrow. If you would like to use the changes immediately, you can download the mpy version from https://github.com/adafruit/Adafruit_Ci ... 0/releases.
MakerMelissa
by terryr on Fri May 24, 2019 5:32 pm
Works like a dream. Thanks for the update.
terryr
