Neopixel Longboard
Neopixel Longboard
by pmtbs2014 on Thu May 23, 2019 5:23 pm
I am trying to help my little brother program the Trinket 5v. Its an older version with the mini b. We are following the walk-thru for the Trinket Neopixel LED Longboard and using the Arduino software and updated drivers from Adafruit.
When I copy the software into Arduino 1.8.6 and 1.8.7, both with Adafruit AVR 1.4.13 Library. Yet, I'm getting 2 errors.
Arduino: 1.8.6 (Windows 10), Board: "Adafruit Trinket (ATtiny85 @ 8MHz)"
sketch_may23d34:1:31: error: Adafruit_NeoPixel.h: No such file or directory
compilation terminated.
exit status 1
I get the above stated when I try to upload it directly from the instructions.
The below is when I omit from line 1-5
C:\Users\pmtja\Desktop\trail323\trail323.ino: In function 'void setup()':
trail323:7:3: error: 'pixels' was not declared in this scope
   pixels.begin();
C:\Users\pmtja\Desktop\trail323\trail323.ino: In function 'void loop()':
trail323:20:7: error: 'pixels' was not declared in this scope
       pixels.setPixelColor(i, color);
trail323:47:30: error: 'pixels' was not declared in this scope
     for (i = 0; i < 54; i++) pixels.setPixelColor(i, 0);
exit status 1
I believe it should all be simple but for some reason its throwing me a curve.....
Any help would be much appreciated.
P.S. I did name and save the programs under 2 different names, as you will see. One for each variant.
pmtbs2014
Re: Neopixel Longboard
by adafruit_support_bill on Thu May 23, 2019 6:25 pm
Sounds like the Arduino IDE is having trouble finding the library file. It is pretty picky about how they are installed. Make sure that Neopixel library is installed in the correct location: https://learn.adafruit.com/adafruit-all ... nstall-use
by pmtbs2014 on Thu May 23, 2019 7:38 pm
avrdude: error: usbtiny_receive: usb_control_msg: sending control message failed, win error: A device attached to the system is not functioning.
 (expected 4, got -5)
It loaded, I think. But now I got the above. I ran thru connections, control panels, properties.
Should I disregard this?
pmtbs2014
by adafruit_support_bill on Thu May 23, 2019 7:40 pm
Is the code running? If the uploaded code seems to be running OK, you can ignore that message.
