LEDs not working with M0
Re: LEDs not working with M0
by franklin97355 on Sat Jun 15, 2019 6:20 pm
Did you install the ARDUINO SAMD boards too?
franklin97355
by batman189 on Sat Jun 15, 2019 6:53 pm
This is the installed Arduino SAMD package I have
batman189
by franklin97355 on Sat Jun 15, 2019 7:17 pm
Can you post the code here? Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created. Or you can post a link to the code if you are copying it from somewhere.
franklin97355
by batman189 on Sat Jun 15, 2019 11:03 pm
/*Original sketch here:
https://hackaday.io/project/9017-skywalker-lightsaber/log/72354-adafruit-trinket-m0-controlling-the-onboard-dotstar-led-via-arduino-ide
get the adafruit dotstar library zip file here:
https://github.com/adafruit/Adafruit_DotStar
tested and works fine on Adafruit Trinket M0
#include <Adafruit_DotStar.h>
#define NUMPIXELS 1 // Number of LEDs in strip
// Here's how to control the LEDs from any two pins:
#define DATAPIN   7
#define CLOCKPIN   8
Adafruit_DotStar strip = Adafruit_DotStar(
  NUMPIXELS, DATAPIN, CLOCKPIN, DOTSTAR_BGR);
  strip.begin(); // Initialize pins for output
  strip.show();  // Turn all LEDs off ASAP
  strip.setPixelColor(0, 0xFF0000); // red
  strip.show();
  delay(1000);
  strip.setPixelColor(0, 0x00FF00); // green
  strip.show();
  delay(1000);
  strip.setPixelColor(0, 0x0000FF); // blue
  strip.show();
  delay(1000);
XRAD was kind enough to give me that code to test with, that is what I have been trying. I have also tried to use the code given in the Arduino section of this adafruit guide: https://learn.adafruit.com/breath-of-th ... d/overview
batman189
by adafruit2 on Sat Jun 15, 2019 11:10 pm
yeah hold on something is amiss with our latest SPI code...
adafruit2
Site Admin
by XRAD on Sun Jun 16, 2019 9:05 am
Thx Batman. Seems like Adafruit2 is on the scene. Look for an update soon in the 'manage libraries.....' or github ..
XRAD
by adafruit2 on Sun Jun 16, 2019 1:50 pm
update samd core to 1.5.1
adafruit2
Site Admin
by batman189 on Sun Jun 16, 2019 5:51 pm
You guys are absoutely outstanding. The code was uploaded and it cycled through the colors on the Trinket just like XRAD said it should. After that was successful I copied the code from the adafruit project in my original post and it worked as well. I am going to put everything back together and give it a test and update you all. Thank you so much for your help!!!
batman189
by XRAD on Mon Jun 17, 2019 7:03 am
Congrats! You just broke into the awesome world of microprocessor programming!
XRAD
