TrinketM0 does not play sound?
by Kroran on Tue Jun 11, 2019 10:22 am
I remember the description saying it can play 10-bit audio but have not had any success in doing so.
Is this a malfunction with my board or do the trinkets just not play audio?
P.s have tried Arduino IDE and Maker Code
Kroran
Re: TrinketM0 does not play sound?
by johnpark on Tue Jun 11, 2019 12:00 pm
Can you share more info on how you're trying to play sound in Arduino and MakeCode on your Trinket M0?
johnpark
by Kroran on Wed Jun 12, 2019 11:33 am
First off (OMFG ITS JOHN PARK!!!! AAAAHHH).
Second I tried using the following code with a piezo speaker or an 8 ohm speaker
using Makercode I use
music.setVolume(10)
forever(function () {
    light.showAnimation(light.rainbowAnimation, 1000)
    light.setAll(0x00ff00)
    music.magicWand.play()
    light.setAll(0xff0000)
    pause(1000)
and Arduin I use this old code I took from a forum
  Arduino Christmas Songs
  Based on a project and code by Dipto Pratyaksa, updated on 31/3/13
  Modified for Christmas by Joshi, on Dec 17th, 2017.
#include "pitches.h"
#define melodyPin 1
// Jingle Bells
int melody[] = {
  NOTE_E5, NOTE_E5, NOTE_E5,
  NOTE_E5, NOTE_G5, NOTE_C5, NOTE_D5,
  NOTE_E5,
  NOTE_F5, NOTE_F5, NOTE_F5, NOTE_F5,
  NOTE_F5, NOTE_E5, NOTE_E5, NOTE_E5, NOTE_E5,
  NOTE_E5, NOTE_D5, NOTE_D5, NOTE_E5,
  NOTE_D5, NOTE_G5
int tempo[] = {
  8, 8, 4,
  8, 8, 4,
  8, 8, 8, 8,
  2,
  8, 8, 8, 8,
  8, 8, 8, 16, 16,
  8, 8, 8, 8,
  4, 4
// We wish you a merry Christmas
int wish_melody[] = {
  NOTE_B3,
  NOTE_F4, NOTE_F4, NOTE_G4, NOTE_F4, NOTE_E4,
  NOTE_D4, NOTE_D4, NOTE_D4,
  NOTE_G4, NOTE_G4, NOTE_A4, NOTE_G4, NOTE_F4,
  NOTE_E4, NOTE_E4, NOTE_E4,
  NOTE_A4, NOTE_A4, NOTE_B4, NOTE_A4, NOTE_G4,
  NOTE_F4, NOTE_D4, NOTE_B3, NOTE_B3,
  NOTE_D4, NOTE_G4, NOTE_E4,
  NOTE_F4
int wish_tempo[] = {
  4,
  4, 8, 8, 8, 8,
  4, 4, 4,
  4, 8, 8, 8, 8,
  4, 4, 4,
  4, 8, 8, 8, 8,
  4, 4, 8, 8,
  4, 4, 4,
  2
// Santa Claus is coming to town
int santa_melody[] = {
  NOTE_G4,
  NOTE_E4, NOTE_F4, NOTE_G4, NOTE_G4, NOTE_G4,
  NOTE_A4, NOTE_B4, NOTE_C5, NOTE_C5, NOTE_C5,
  NOTE_A4, NOTE_G4, NOTE_F4, NOTE_F4,
  NOTE_E4, NOTE_G4, NOTE_C4, NOTE_E4,
  NOTE_D4, NOTE_F4, NOTE_B3,
  NOTE_C4
int santa_tempo[] = {
  8,
  8, 8, 4, 4, 4,
  8, 8, 4, 4, 4,
  8, 8, 4, 4, 4,
  8, 8, 4, 2,
  4, 4, 4, 4,
  4, 2, 4,
  1
int switchOne = 0;
int switchTwo = 0;
int switchThree = 0;
void setup(void) {
  pinMode(1, OUTPUT); // Buzzer
  pinMode(13, OUTPUT); // Led indicator when singing a note
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  switchOne = digitalRead(2);
  switchTwo = digitalRead(3);
  switchThree = digitalRead(4);
  if (switchOne == HIGH) {
    sing(1);
  } else if (switchTwo == HIGH) {
    sing(2);
  } else if (switchThree == HIGH) {
    sing(3);
int song = 0;
void sing(int s) {
  // iterate over the notes of the melody:
  song = s;
  if (song == 3) {
    Serial.println(" 'We wish you a Merry Christmas'");
    int size = sizeof(wish_melody) / sizeof(int);
    for (int thisNote = 0; thisNote < size; thisNote++) {
      // to calculate the note duration, take one second
      // divided by the note type.
      //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
      int noteDuration = 1000 / wish_tempo[thisNote];
      buzz(melodyPin, wish_melody[thisNote], noteDuration);
      // to distinguish the notes, set a minimum time between them.
      // the note's duration + 30% seems to work well:
      int pauseBetweenNotes = noteDuration * 1.30;
      delay(pauseBetweenNotes);
      // stop the tone playing:
      buzz(melodyPin, 0, noteDuration);
  } else if (song == 2) {
    Serial.println(" 'Santa Claus is coming to town'");
    int size = sizeof(santa_melody) / sizeof(int);
      int noteDuration = 900 / santa_tempo[thisNote];
      buzz(melodyPin, santa_melody[thisNote], noteDuration);
  } else {
    Serial.println(" 'Jingle Bells'");
    int size = sizeof(melody) / sizeof(int);
      int noteDuration = 1000 / tempo[thisNote];
      buzz(melodyPin, melody[thisNote], noteDuration);
void buzz(int targetPin, long frequency, long length) {
  digitalWrite(13, HIGH);
  long delayValue = 1000000 / frequency / 2; // calculate the delay value between transitions
  //// 1 second's worth of microseconds, divided by the frequency, then split in half since
  //// there are two phases to each cycle
  long numCycles = frequency * length / 1000; // calculate the number of cycles for proper timing
  //// multiply frequency, which is really cycles per second, by the number of seconds to
  //// get the total number of cycles to produce
  for (long i = 0; i < numCycles; i++) { // for the calculated length of time...
    digitalWrite(targetPin, HIGH); // write the buzzer pin high to push out the diaphram
    delayMicroseconds(delayValue); // wait for the calculated delay value
    digitalWrite(targetPin, LOW); // write the buzzer pin low to pull back the diaphram
    delayMicroseconds(delayValue); // wait again or the calculated delay value
  digitalWrite(13, LOW);
Kroran
by johnpark on Wed Jun 12, 2019 1:10 pm
ha! So I don't get any sound using the MakeCode Maker code either, I've submitted a bug: https://github.com/microsoft/pxt-maker/issues/234
I'll try Arduino next as well as CircuitPython.
johnpark
by Kroran on Wed Jun 12, 2019 1:15 pm
OMG thank you!! your awesome dude, keep doing what you do.
Kroran
by Kroran on Tue Jun 25, 2019 10:23 am
any news on this?
Kroran
by johnpark on Tue Jun 25, 2019 12:17 pm
The github issue is the best place to check for updates. https://github.com/microsoft/pxt-maker/issues/234
johnpark
