TRINKET MO WILL NOT LOAD BLINK
by williamlynn on Sat Jun 15, 2019 7:16 pm
I have a new TRINKET MO and it will not load the BLINK example.
So far I have
a. deleted ARDUINO 1.8.9 and reloaded after deleting the ARDUINO15 directory and all other ARDUINO files I could find and then doing a REGISTRY CLEAN.
b Done his several times
Attached are the error codes in regular and verbose formats.
Help appreciated
Bill
TRINKET_MO_ERROR_verbose.txt
(24.94 KiB) Downloaded 38 times
TRINKET_MO_ERROR.txt
(2.7 KiB) Downloaded 35 times
williamlynn
Re: TRINKET MO WILL NOT LOAD BLINK
by franklin97355 on Sat Jun 15, 2019 8:33 pm
Do you have both the Adafruit and the Arduino SAMD packages installed?
franklin97355
by williamlynn on Sun Jun 16, 2019 8:09 am
YES, both packages are installed;
Arduino SAMD Boards Version 1.8.1
Adafruit SAMD Boards Version 1.5.0
I am running Windows 10.
I have done everything that I could find in the forums; deleted all versions of Arduino, Deleted ARDUINO15 Folders, cleaned registry, removed all traces of Arduino before reloading the latest Arduino 1.8.9
Help appreciated
Bill
williamlynn
by XRAD on Sun Jun 16, 2019 8:43 am
a few basic things to check:
If you have partially removed an Arduino file or have a corrupt/duplicate file remaining, this may still be in the system... I had to use Revo uninstaller (I used free version initially, then ended up buying it because it works so well) to get as much Arduino files removed as possible
The order of install of SAMD boards: Arduino first, then Adafruit
One issue that is common is the USB cable type. Are you using a data or charging cable?
does the sketch compile in the IDE? I saw the errors....
Trinket M0 board selected from IDE dropdown menu?
Do you see the trinket M0 on a 'port'?
double click the bootloader button on the trinket M0 and see if you get the bootloader file window (you may have to 're-check' port selection box to attach new port......)
see pics below:
DOT BOARD.JPG (222.11 KiB) Viewed 83 times
DOT PORT.JPG (91.24 KiB) Viewed 83 times
XRAD
by williamlynn on Sun Jun 16, 2019 8:48 am
Overnight a new version of the Adafruit SAMD Boards was posted ; it is now Version 1.5.1 and it works
Now on to the next problem which I will open a new post.
williamlynn
by XRAD on Sun Jun 16, 2019 8:54 am
Cool! This may be the answer for a few other members with upload issues....
XRAD
