๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
No serial USB port for mac in Arduino IDE
by jwbacn on Sat Jun 29, 2019 10:55 pm
I have an Arduino Trinket 5v I am trying to connect to my computer via USB. When I click Tools>Port there are no USB options listed. It shows multiple /dev/cu.XXXX options which are bluetooth related.
Screen Shot 2019-06-29 at 7.50.22 PM.png (1002.52 KiB) Viewed 201 times
I have tried on my 2016 Macbook Pro Mojave with no luck, and have looked on StackExchange and have tried installing CH 34X drivers to no avail. I have also tried on a 2013 Macbook Air Mojave and it doesn't work.
I have downloaded the trinket libraries and have selected the board as 'Pro Tinket 5V/16MHz (FTDI)' although I don't think this is related to the port. I have tried multiple cables and am using one that *does connect* to an Adafruit Pyportal.
The tutorial I was following says no drivers required on the mac. Thanks for your help!
jwbacn
Re: No serial USB port for mac in Arduino IDE
by adafruit_support_mike on Sun Jun 30, 2019 1:19 am
The Pro Trinket doesn't register as a Serial Port in the Arduino IDE.
The board doesn't have any real USB hardware, the bootloader just emulates a low-speed USB connection long enough to upload firmware. The details are explained in the tutorial:
https://learn.adafruit.com/introducing- ... rduino-ide
by jwbacn on Sun Jun 30, 2019 4:03 pm
Hey Mike thanks for your reply. I'm still confused. Can I use the microUSB at all? Or do I need to purchase something else like this?
https://www.adafruit.com/product/954
The tutorial didn't list that as a necessary part.
Also I'm using Arduino 1.8.9 - is the bug referenced in your link squashed in this newer version?
There's nothing referenced in the tutorial about this (https://learn.adafruit.com/bike-wheel-p ... y/overview).
jwbacn
by adafruit_support_mike on Mon Jul 01, 2019 1:21 am
You can program the Pro Trinket through the micro-USB jack without using an external USB-to-Serial converter. You just have to reset the board manually to force the bootloader to launch and start emulating a USB connection when the IDE is ready to upload the firmware.
It's all covered on the tutorial page linked above.
by philosocrates on Fri Aug 16, 2019 5:03 pm
Same issue on my Mac. Same Mac that he's been used to program 2 5v Pro Trinkets in the past. Cable is good. The IDE just can't find it.
Arduino: 1.8.9 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 3912 bytes (12%) of program storage space. Maximum is 32256 bytes.
Global variables use 41 bytes (2%) of dynamic memory, leaving 2007 bytes for local variables. Maximum is 2048 bytes.
/Users/mikemadden/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/mikemadden/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.Bluetooth-Incoming-Port -b115200 -D -Uflash:w:/var/folders/px/dfyfbpq56wv9kxpwrwc3gpmw0000gn/T/arduino_build_212139/Tauren.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/mikemadden/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
User configuration file is "/Users/mikemadden/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.Bluetooth-Incoming-Port
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
philosocrates
