๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Controlling a stepper motor using adafruit trinket
by dvbaker on Mon Jul 15, 2019 5:01 pm
I'm new to robotics and recently purchased an adafruit trinket with hopes to control a 5v 2 stage 4 wire stepper motor. The project I'm working on calls for a very small controller for the motor which Is why I decided on the trinket. My question is, is it possible to program a set of repeated commands on the trinket for the motor? Thank you to everyone willing to reply!
dvbaker
Re: Controlling a stepper motor using adafruit trinket
by adafruit_support_bill on Mon Jul 15, 2019 5:10 pm
The Trinket can't drive a motor directly. For a stepper motor, you need a dual H-bridge motor driver. To determine the driver requirements we'd first need to know the full electrical specifications for the motor.
by dvbaker on Mon Jul 15, 2019 5:54 pm
Appreciate the quick response, the motor I ordered is a
NW High Torque 5V Dc 2 Phase 4 Wire Dia 15mm Stepper Motor With Micro Planetary Reducer With Bevel gear
(https://www.amazon.com/gp/product/B01IN ... UTF8&psc=1)
dvbaker
by adafruit_support_bill on Mon Jul 15, 2019 6:18 pm
OK. That is compatible with several of our motor drivers.
Which version of the Trinket do you have?
by dvbaker on Mon Jul 15, 2019 6:23 pm
I have the 5v and 3.3v currently. So will the trinket will be used to set the commands for the motor controller?
dvbaker
by adafruit_support_bill on Mon Jul 15, 2019 6:35 pm
Those Trinkets have very limited pins. There are 5 GPIO pins, but two serve double-duty for programming via USB, so you really have only 3 that you can use without restrictions.
https://learn.adafruit.com/introducing- ... o-pins-3-8
A plain dual H-bridge like the L293D, TB6612 or the DRV8833 need at least 4 pins for control. You could use them with a Trinket, but you may need to disconnect some of the wires in order to upload programs to the Trinket.
https://www.adafruit.com/product/807
https://www.adafruit.com/product/2448
https://www.adafruit.com/product/3297
One option is to use the motor/stepper wing. This uses a PCA9865 to control 2 of the TB6612 drivers - using just the SDA and SCL pins. It is made to plug directly into a Feather processor, but you can wire it to the Trinket via jumpers.
https://www.adafruit.com/product/2927
Another option would be to use one of the 2-pin step & direction drivers. These use 1 pin for direction control and another for the stepping. www.pololu.com carries a wide selection of step & direction controllers.
by dvbaker on Thu Jul 18, 2019 5:08 pm
I ordered both the L293D, TB6612, and the featherwing.. I'm still pretty confused if I can do what I need to though. Can I program a set of instructions to the trinket to be relayed to the L293D and then to the stepper motor indefinitely?
dvbaker
by adafruit_support_bill on Thu Jul 18, 2019 6:21 pm
Those motor drivers are simple H-bridge drivers. They do not have any local intelligence to execute instructions. You need to control their inputs step-by-step from the Trinket. You can use the Arduino Stepper library for that: https://www.arduino.cc/en/reference/stepper
With either of those drivers, you will need 4 pins to control it. As mentioned in my previous response, the Trinket has only 3 pins that can be used without restriction. You may need to disconnect a the 4th pin while uploading programs to it.
