๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
need battery solution
by juansoria on Thu Aug 01, 2019 2:16 pm
I'm building a M0 driven 16 to 24 neopixel art project and need it to run for 7 to 10 days. The project will include a PCF8523 real time clock to shut down the M0 during the day, then reactivate it at night. I would love some battery power suggestions.
I'm thinking about an array of D cell batteries so we can deliver as many amp hours as possible, but more elegant ideas are welcome!
juansoria
Re: need battery solution
by XRAD on Thu Aug 01, 2019 3:04 pm
How bright are the neopixels? Assuming full brightness, plus board power...rough guess is that one 5000mah 2s lipo w/small 5v 2 amp regulator will give you ~5 days for typical northern hemisphere summer night.
a small light sensor directly triggering the M0 may draw less power than the oscillator board, easier to program, and sensitivity range can be set to turn on/off. Example hardware/code of the adafruit light sensor can be found on the Hallowing....
the other thought is something like this:
https://www.adafruit.com/product/3435
maybe adafruit has a low power timer incorporated into a longer clock based board so that you can turn on/off without having to supply power to the M0 for unused 12 hours of day....
XRAD
by adafruit_support_bill on Thu Aug 01, 2019 3:58 pm
No need for a 2s battery or regulator. The pixels will run perfectly well powered directly by a 1s (3.7v) LiPo cell. The same cell could power the M0 as well.
https://www.adafruit.com/product/354
https://www.adafruit.com/product/353
