need battery solution
by juansoria on Thu Aug 01, 2019 2:16 pm
I'm building a M0 driven 16 to 24 neopixel art project and need it to run for 7 to 10 days. The project will include a PCF8523 real time clock to shut down the M0 during the day, then reactivate it at night. I would love some battery power suggestions.
I'm thinking about an array of D cell batteries so we can deliver as many amp hours as possible, but more elegant ideas are welcome!
juansoria
Re: need battery solution
by XRAD on Thu Aug 01, 2019 3:04 pm
How bright are the neopixels? Assuming full brightness, plus board power...rough guess is that one 5000mah 2s lipo w/small 5v 2 amp regulator will give you ~5 days for typical northern hemisphere summer night.
a small light sensor directly triggering the M0 may draw less power than the oscillator board, easier to program, and sensitivity range can be set to turn on/off. Example hardware/code of the adafruit light sensor can be found on the Hallowing....
the other thought is something like this:
https://www.adafruit.com/product/3435
maybe adafruit has a low power timer incorporated into a longer clock based board so that you can turn on/off without having to supply power to the M0 for unused 12 hours of day....
XRAD
by adafruit_support_bill on Thu Aug 01, 2019 3:58 pm
No need for a 2s battery or regulator. The pixels will run perfectly well powered directly by a 1s (3.7v) LiPo cell. The same cell could power the M0 as well.
https://www.adafruit.com/product/354
https://www.adafruit.com/product/353
