Issues with AnalogIn function - possible noise?
by tylerk666666 on Fri Aug 09, 2019 2:56 pm
I've been working on trying to get a voltage reading from an input to the Trinket m0. Was feeding in about .5 V to one of the I/O ports, and was getting a voltage reading of about 40,000 out of the 65535 scale that the device outputs voltages in. Converted voltage reading is about 2V out of 3.3 V device can handle. However, even when disconnecting the voltage input and just reading the voltage of the pin while the device isn't connected to a signal- still getting around this same voltage reading. Is there an issue with noise of the devices? Would assume voltage should be around 0V . Any help on the Analog In function, alternate ways of getting voltage readings, noise troubleshooting, etc. would be helpful.
tylerk666666
Re: Issues with AnalogIn function - possible noise?
by franklin97355 on Fri Aug 09, 2019 3:01 pm
Try shorting the pin to ground and see what you get.
franklin97355
by tylerk666666 on Fri Aug 09, 2019 6:18 pm
franklin97355 wrote:Try shorting the pin to ground and see what you get.
This is code I'm using:
import board
import analogio
import time
adc0 = analogio.AnalogIn(board.A2)
adc1 = analogio.AnalogIn(board.A0)
adc2 = analogio.AnalogIn(board.A1)
print(adc0.value)
print(adc1.value)
print(adc2.value)
I shorted pin 0 and pin 1~ to ground, no connection to pin 2-
returned voltage values are:
53664
31488
41360
Not sure what else could be wrong- if USB is connected to computer via device can Batt and 3V pins be left be or do they need to be connected?
tylerk666666
by tylerk666666 on Wed Aug 14, 2019 10:11 am
import board
import analogio
import time
print(adc0.value)
print(adc1.value)
print(adc2.value)
53664
31488
41360
Any ideas?
tylerk666666
