Pro Trinket Tachometer using 5V ItsyBitsy 32u4
by stanleytpig on Sat Aug 17, 2019 5:42 pm
Hello, I am attempting to build a “Pro Trinket Tachometer” following instructions on your website (https://learn.adafruit.com/pro-trinket- ... uit-design); however, I am substituting the 5V ItsyBitsy 32u4 for the Pro Trinket. I have a couple of questions; 1) Can I use the same pins identified for the Pro Trinket on the ItsyBitsy, meaning are A3, A4, and 3 on Pro Trinket the same as A3, A4 and 3 on the ItsyBitsy? From the ItsyBitsy pinout it looks like logic pins 2 and 3 are for I2C – I am very confused. Also, it appears that ItsyBitsy logic pin 3 does not have a pullup resistor.
Well I’m guessing that on the ItsyBitsy I should use logic pin #2 as I2C data pin, pin #3 as the I2C clock pin – is this correct and do I need pull-up resistors for I2C? Lastly, on the ItsyBitsy can I use logic pin #4 as the sensor input from the Reflective IR Sensor and will I need to use a pullup resistor? Any assistance you can provide would be greatly appreciated. Thanks.
stanleytpig
Re: Pro Trinket Tachometer using 5V ItsyBitsy 32u4
by adafruit_support_bill on Sun Aug 18, 2019 8:02 am
The pinouts of the 32U4 for both interrupts and the i2c bus are different. You need to use Pins 2 and 3 for SDA and SCL. Pullups are not necessary if you are using one of our display boards.
That leaves pins 0, 1 and 7 as options for the interrupt input. All pins have internal pullups that can be enabled via pinmode.
by stanleytpig on Sun Aug 18, 2019 2:38 pm
that is perfect - thanks very much.
stanleytpig
