Adafruit I2S MEMS Microphone Breakout with Trinket M0
by JSE98 on Mon Apr 27, 2020 12:17 am
I'm trying to interface the Adafruit I2S MEMS Microphone Breakout with the Trinket M0, but having trouble figuring out how to wire and read from it. The instructions (https://learn.adafruit.com/adafruit-i2s ... g-and-test) don't list what pins to use on the Trinket M0, and on the board used as an example the I2C SDA/SCL pins aren't used, which I'm confused about because it is an I2C device.
Also, once I get it wired properly, can I use CircuitPython to read from it?
Thank you so much for your help!
JSE98
Re: Adafruit I2S MEMS Microphone Breakout with Trinket M0
by adafruit_support_carter on Mon Apr 27, 2020 6:33 pm
The Trinket M0 does not have I2S support.
I2S is different than I2C. It's unfortunate the names only differ by one letter. It leads to a lot of confusion.
The Trinket M0 does have I2C support.
CircuitPython does have support for I2S output:
https://learn.adafruit.com/adafruit-i2s ... iring-test
but at this time, no support for I2S input.
by JSE98 on Mon Apr 27, 2020 11:22 pm
Oh haha, I can't believe I didn't notice that!
Thank you for the response :)
JSE98
