Trinket 5V all NeoPixels light up
by sahteck on Wed May 06, 2020 3:29 am
I'm trying to test using a 5v Trinket with a NeoPixel strip.
The strip is 60 NeoPixels long, of the 30/m variety. I wired the appropriate things to ground, USB, and #0 or #1 (tried using different PWM pins) and running the simple code in the NeoPixel example, but for some reason the whole strip lights up either white or red when I move it a little bit. Sometimes only the first pixel will be green.
I haven't soldered anything, just made sure the wires made good contact with the appropriate pins on the Trinket and tried breadboarding (there's a few inches of wire between the strip and Trinket, if that's relevant, but it can be reduced). The code has it declared to be a strip of 16 pixels, and when I use it with my Arduino Uno it behaves properly.
Any suggestions are welcome.
sahteck
Re: Trinket 5V all NeoPixels light up
by dastels on Wed May 06, 2020 9:20 am
It does sound like a bad connection. Especially as it changes when things are moved.
I suggest you solder the connections.
dastels
by sahteck on Wed May 06, 2020 12:43 pm
Resolved once I added headers! Thanks for pointing out the connection issue.
sahteck
