Modifying Trinket USB Keyboard code: Not compling
by 77slevin on Sun May 10, 2020 8:57 am
I am using a Amiga Emulator with an original Amiga 1200 Case. This keyboard only goes from F1-F10 function keys, but what do you know... FS-UAE needs F12 to get into preferences/configuration.
So my idea was to modify the code from https://learn.adafruit.com/trinket-usb-keyboard/code and make the key press F12.
this line in the code says press shift and press A to print a capital A.
TrinketKeyboard.pressKey(KEYCODE_MOD_LEFT_SHIFT, KEYCODE_A);
So with my limited knowledge, I thought adapting the code to:
TrinketKeyboard.pressKey(KEYCODE_F12);
Would do the trick seeing I don't need the shift modifier for F12...alas no joy.
the code fails to compile and trows a
exit status 1
no matching function for call to 'Trinket_Keyboard::pressKey(int)'
What am I doing wrong?
77slevin
Re: Modifying Trinket USB Keyboard code: Not compling
by dastels on Sun May 10, 2020 10:12 am
The pressKey methods all take the modifiers as an initial argument. There is not one that takes just a keycode. Looking at the header will give you all the method signatures which documents what can be called, and with what arguments. See https://github.com/adafruit/Adafruit-Trinket-USB/blob/master/TrinketKeyboard/TrinketKeyboard.h.
If you don't want modifiers pressed, pass a 0 as the first argument.
The modifier constants consititute an 8-bit value with each modifier key represented by one of the bits. You binary-or together the ones you want. E.g. For left-control and left-shift:
KEYCODE_MOD_LEFT_CONTROL   |  KEYCODE_MOD_LEFT_SHIFT
dastels
by 77slevin on Sun May 10, 2020 10:21 am
Thanks Dave, that did the trick! I can now access my config interface.
77slevin
