Help trinket 5v neopixel
by JorenSmet on Mon May 11, 2020 6:56 pm
I'm trying to get my trinket to just show a purple color across all the leds of my neopixel stick (8leds) but i can't seem to figure it out.
This is what i have so far:
#ifdef __AVR__
 #include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN    1
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 8
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRBW + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
   // These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
  // Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  clock_prescale_set(clock_div_1);
#endif
  // END of Trinket-specific code.
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  strip.setPixelColor(0, 0, 100, 100, 20);
  strip.setPixelColor(7, 0, 100, 100, 20);
  // put your main code here, to run repeatedly:
(trinket: https://www.adafruit.com/product/1501)
thanks in advance!
JorenSmet
Re: Help trinket 5v neopixel
by adafruit_support_carter on Mon May 11, 2020 7:35 pm
Are you able to upload and run the basic blink example OK?
https://learn.adafruit.com/introducing- ... #blink-6-5
That version of the Trinket is deprecated. So just want to make sure you are actually able to program it. Here's the newer version of the Trinket:
https://www.adafruit.com/product/3500
To set all pixels to a specific color, use the fill() method:
https://github.com/adafruit/Adafruit_Ne ... xel.h#L216
Also, don't forget to call show() to actually have the updated colors sent out to the NeoPixels.
