Circuit playground express
by simsim14 on Sat Jun 06, 2020 11:30 am
The controller (circuit playground express) you sent me is defective, what is the procedure for changing it, to what address can I return it to you? you will see for yourself that he has a problem. Thank you for understanding
simsim14
Re: Circuit playground express
by dastels on Sat Jun 06, 2020 8:33 pm
How is it defective? What behavior are you seeing?
dastels
by simsim14 on Sat Jun 06, 2020 9:17 pm
the battery is functional, but the controller does not react, I am an electronic technician, I am sure and certain that it is defective, I need it so much for work, I couldn't wait for you to change it for me, I bought another one today on amazon canada, I paid an extra to receive it tomorrow on Sunday
see attached files
thanks for your understanding
simsim14
by dastels on Sun Jun 07, 2020 1:25 pm
I can understand the urgency, and if we can determine conclusively that it's defective it'll be replaced.
dastels
by simsim14 on Sun Jun 07, 2020 1:36 pm
I measure the battery, the turnout is good, but once the controller connected to the battery no light comes on, I click on the buttons nothing either, it's as if the controller is not connected to any source of power.
simsim14
by dastels on Sun Jun 07, 2020 1:41 pm
What happens when you connect it to a computer via USB?
dastels
by simsim14 on Sun Jun 07, 2020 1:46 pm
only a small green light next to it that lights up, I press the button to try to program it no light comes on
simsim14
by dastels on Sun Jun 07, 2020 2:35 pm
What happens if you double press reset?
dastels
by simsim14 on Sun Jun 07, 2020 2:38 pm
when i double click on the reset button (little black) nothing happens
simsim14
by dastels on Sun Jun 07, 2020 3:13 pm
OK, please email support@adafruit.com with a link to this thread, your order number, and request the replacement of one circuitplayground express.
dastels
by simsim14 on Thu Jun 11, 2020 7:14 pm
The circuit playground express you sent me is good this time, thank you very much for your patience. Please see the photos.
Currently the servo motor turns only 45 degrees, what I need to change to the code so that it opens and closes at 90 degrees.
thank you so much
simsim14
by dastels on Thu Jun 11, 2020 8:11 pm
I don't tend to use Makecode, but I see a couple things...
You use servo write pin and servo set pulse pin but I think you need one or the other. Servos work by converting pulse widths to a rotation angle. You can directly control the pulse width or let the library figure out the pulse width based on an angle you specify.
The value servo write pin block expects is an angle in degrees (between 0 and 180, inclusive).
FWIW, a decent introduction to how servos work is https://resources.kitronik.co.uk/pdf/a-brief-guide-to-servos.pdf.
dastels
by simsim14 on Fri Jun 12, 2020 1:16 pm
unfortunately I didn't manage to change the opening and closing angle of the servo, I changed the numbers on the code, but it didn't work
simsim14
by dastels on Fri Jun 12, 2020 1:48 pm
Have you tried a different servo. There can be some variance between units, though this seems like a lot.
What happens if you tried 0 and 180? Through how much of an angles does the horn move?
dastels
by simsim14 on Fri Jun 12, 2020 2:06 pm
I am not a programmer, I have no knowledge of javascript, I have no idea or should I put (0 a180), everything I did, I changed the numbers on the coded
simsim14
