Serial.print /SerialUSB print in Arduino IDE with M0 Trinket
by OriginP on Sun Jun 07, 2020 4:26 pm
I've been trying to use Serial.print and serial.read with the M0 Trinket USB port using the Arduino IDE. I want to use the USB port to send and receive data between the M0 Trinket and a PC. No luck with finding examples or explanations outside of the Adafruit note saying Adafruit uses Serial.x while official Arduino uses SerialUSB.x.
Serial.x is usually so easy to use. I must be missing something significant as to how it has changed with M0 Trinket. Any advice or suggestions would be greatly appreciated.
Thank you,
Eric
OriginP
Re: Serial.print /SerialUSB print in Arduino IDE with M0 Tri
by dastels on Mon Jun 08, 2020 10:33 am
Is your code stalling on setting up the serial connection?
dastels
by gajillion on Tue Jun 23, 2020 10:18 pm
Make sure you have this after your Serial.begin statement
while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
gajillion
by rmoquin on Sun Jul 05, 2020 10:55 am
I too had been struggling getting serial output from my Trinket M0 (which are broken now, which will be a different post), but if this is needed for the M0, it could be helpful to have a note or reminder added to the docs. Maybe it's obvious, but I completely forgot about trying it as I've been struggling to figure it out. I don't work with Arduino consistently enough to remember to try certain things like this unfortunately.
rmoquin
