It seems that the DotStar will emit unless you specifically turn it off. Meaning, if your code (CircuitPython, Arduino) does not explicitly control the DotStar, it'll always turn on, full brightness, blinding you and using a ton of power.
Is there some way to disable that thing so that it does not turn on unless explicitly commanded to do so?
How to disable the DotStar?
- mikeysklar
Re: How to disable the DotStar?
@dlc_op,
Can you be a little more specific about your setup? Are you using a DotStar strip or is it the individual LED on one of our Adafruit boards that you wish to have completely off? If it is a strip or other external DotStar layout please let me know what type of device you are driving it with (Pi, Feather, UNO, etc.). Are you using Circuit Python or Arduino?
- dlc_op
The DotStar built in to the Trinket M0
- mikeysklar
The built-in DotStar can turned off with something like the following example code.
import time
import board
# For Trinket M0, Gemma M0, ItsyBitsy M0 Express, and ItsyBitsy M4 Express
import adafruit_dotstar
led = adafruit_dotstar.DotStar(board.APA102_SCK, board.APA102_MOSI, 1)
led.brightness = 0
led[0] = (0, 0, 0)
led.show()
- dlc_op
Understood, and I am doing that.
However, in the brief moment between when the power is applied and that code is run, the DotStar turns on full, resulting in a quick bright flash.
Is there no way to prevent that flash?
For example, does the DotStar have some config field that can be set & which survives power cycling?
Seems odd that the DotStar would default to "full on".... every peripheral I've ever used defaults to off and you must explicitly command it to an on state.
- mikeysklar
I believe there are two options which you will have to explore further on your own.
1. Use boot.py which runs before code.py, but might not be early enough for you. In which case you should be able to use my python example for shutting off the code.
2. Build your own CircuitPython. Seems kind of extreme and probably a lot more convenient to cut the LED trace on your trinket.
https://learn.adafruit.com/building-cir ... cuitpython
- dlc_op
I'll cut the trace :)
- jkaiser20
Did this work easily for you? I hate to kill it forever, but man that thing is annoying.dlc_op wrote:I'll cut the trace :)
