Power supply for Trinket M0 and Neopixel
by Bromley47 on Fri Nov 20, 2020 3:36 pm
I am hoping to use a Trinket M0 - for use with CircuitPython & Arduino IDE with a 16 LED NeoPixel ring - what sort of power supply should I use for the board?
And can I connect from the board USB to the Neopixel? Would this give me 3v or 5v to the Neopixel?
Bromley47
Re: Power supply for Trinket M0 and Neopixel
by adafruit_support_carter on Fri Nov 20, 2020 3:37 pm
Good info on powering in the uberguide:
https://learn.adafruit.com/adafruit-neo ... -neopixels
by johnmark on Fri Nov 27, 2020 2:06 am
Thanks for posting the link. For the m0, I couldn't tell what the specs were for a power supply - when connected to my laptop's USB port, running 'lsusb -vv' tells me that it supports a maximum of 100mA - which I suppose answers my next question: why my laptop has no problem powering the trinket M0 plus a 16 neopixel ring, but my pocket USB charger crashes it instantly - it's rated at a maximum of 1A, but I just assumed it would only supply the amount of power requested by a device. Since that is not the case, can you give me a recommendation? Because I don't want to carry around my laptop just so i can run the trinket :)
I just bought this in the hope that it will be a solution: https://www.adafruit.com/product/1944
-JM
johnmark
by johnmark on Sun Nov 29, 2020 3:23 pm
It works! After plugging in the powerboost 500, the trinket m0 was still crashing, and I was about to pull my hair out. All I wanted to do was to get the demo program running. Taking a cue from this Q&A - viewtopic.php?f=52&t=170308 - I commented out the import of anything related to keyboard and keycode, and now it works.
Being a complete n00b, this is a great example of the sort of stuff that can trip me up. I had no idea that importing those libs would crash the device if there's no keyboard or other HID device detected.
johnmark
by johnmark on Mon Nov 30, 2020 4:10 pm
And here's the final product - I can quibble with some of the finer aspects of the PETG print as well as the soldering, but it looks pretty nice.
Based on this project - https://www.instructables.com/The-Neopixel-LED-Vase/
johnmark
