Trinket Pro 5.0v
- pmerz3
Trinket Pro 5.0v
I purchased a Trinket Pro recently and the computer does not recognize the board. I am using arduino IDE for programming as I also have some Uno's. I have downloaded the latest driver pack for Adafruit and installed. When the board is plugged into the computer, the board lights up, solid green and flashing red, but going into control panel shows no board hooked up. How do I fix this?
Re: Trinket Pro 5.0v
As noted in the product description, these boards have been deprecated due to compatibility issues with newer USB ports. https://www.adafruit.com/product/2000
If you have an old USB 1.0 or 2.0 hub, you can try connecting through that. Otherwise, your best bet is to use an FTDI cable as described in the guide: https://learn.adafruit.com/introducing- ... using-ftdiDeprecation Warning: The Pro Trinket bit-bang USB technique it uses doesn't work as well as it did in 2014, many modern computers won't work well. So while we still carry the Pro Trinket so that people can maintain some older projets, we no longer recommend it.
- pmerz3
I do have usb 2 hub, which I connected the trinket pro though it. Still the same problem. The computer does not recognize the trinket.
Your best bet then is to use an FTDI cable. Since the Atmega328 does not have native USB support, we implemented it in software for the Trinkets. This worked well in USB 1.0, but the higher speeds of newer USB standards also required tighter timing constraints that were not possible to meet in software. It will work with some, but not all USB 2.0 ports. I have not seen it work at all with 3.0.
- sydcomebak
Can you explain how the FTDI connects to the Trinket (not Pro) 5.0v?
-David
-David
Not sure that it can. The ATTiny85 does not have a native hardware UART.Can you explain how the FTDI connects to the Trinket (not Pro) 5.0v?
