I looked at the the code in the "Adafruit_TinyFlash" library and was wondering if using a BANNED instead of W25Q80BV would be as easy as just changing these lines:
// Currently rigged for W25Q80BV only
#define CHIP_BYTES 1L * 1024L * 1024L
to these lines:
// for W25Q80BV only (8 Mbit = 1 Mbyte)
//#define CHIP_BYTES 1L * 1024L * 1024L
//#define MAN_ID 0xEF
//#define DEV_ID 0x13
// for BANNED (32 Mbit = 4 Mbyte)
#define CHIP_BYTES 4L * 1024L * 1024L
#define MAN_ID 0xEF
#define DEV_ID 0x15
And changing these lines:
// Chip capacity is hardcoded for now
return ((manID == 0xEF) && (devID == 0x13)) ? CHIP_BYTES : 0L;
to these lines:
// Chip capacity is hardcoded for now by defines
return ((manID == MAN_ID) && (devID == DEV_ID)) ? CHIP_BYTES : 0L;
I have the datasheets for both chips and was wondering if this was all I needed to change before spending a lot of time comparing the two data sheets.
Thanks, Joe.
change Adafruit_TinyFlash to use other W25Q chips
- szedula
- mikeysklar
Re: change Adafruit_TinyFlash to use other W25Q chips
Joe,
You can see in our CircuitPython archive we do support this device as W25Q16JV_IQ. Maybe some defining features in there for you to review before making any changes to tiny_uf2.
https://github.com/adafruit/circuitpyth ... /devices.h
Your suggested mods look like a reasonable change. It's just a bigger flash chip right? If your changes work why not open an Issue with the repo as a feature request to support this chip with your proposed code merge. They'll either merge it or point you towards another resource.
https://github.com/adafruit/Adafruit_TinyFlash/issues
- plutonic
Wait, sorry to cut in but is this about the Trinket M0? Does the board have a pad for a serial flash chip? The product page doesn't mention anything about that, but I'd love to add more flash to my Trinket.
- mikeysklar
The QtPy is using the same processor as the Trinket M0 and it has the flash 8-SOIC available for a memory upgrade. No dice on the Trinket M0.
https://www.adafruit.com/product/4600
