Bluetooth NeoPixel Goggle project
jcafiero86
Post by jcafiero86 »
I just finished putting this little project together using the tutorial provided by Adafruit. I'm very happy everything worked with the code since I'm not very experienced with coding.
But now that I have it running I would like to add or change one or all of the patterns in the code but I'm not familiar with this level of coding. Below is the full project code with a link to the tutorial.
If someone can help or explain how to add more pattern modes that would be appreciated. I know that with trinket memory is an issue so thats why am asking for some assistance with this.
Tutorial
https://learn.adafruit.com/bluetooth-neopixel-goggles
This is the full project code with 2 programed modes. I would like to replace the modes but I cant identify what needs to be chance
#include <SoftwareSerial.h>
#ifdef __AVR_ATtiny85__ // Trinket, Gemma, etc.
 #include <avr/power.h>
#endif
#define RX_PIN    2 // Connect this Trinket pin to BLE 'TXO' pin
#define CTS_PIN   1 // Connect this Trinket pin to BLE 'CTS' pin
#define LED_PIN   0 // Connect NeoPixels to this Trinket pin
#define NUM_LEDS 32 // Two 16-LED NeoPixel rings
#define FPS      30 // Animation frames/second (ish)
SoftwareSerial    ser(RX_PIN, -1);
Adafruit_NeoPixel pixels(NUM_LEDS, LED_PIN);
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000L)
  // MUST do this on 16 MHz Trinket for serial & NeoPixels!
  clock_prescale_set(clock_div_1);
#endif
  // Stop incoming data & init software serial
  pinMode(CTS_PIN, OUTPUT); digitalWrite(CTS_PIN, HIGH);
  ser.begin(9600);
  pixels.begin(); // NeoPixel init
  // Flash space is tight on Trinket/Gemma, so setBrightness() is avoided --
  // it adds ~200 bytes.  Instead the color picker input is 'manually' scaled.
uint8_t  buf[3],              // Enough for RGB parse; expand if using sensors
         animMode = 0,        // Current animation mode
         animPos  = 0;        // Current animation position
uint32_t color    = 0x400000, // Current animation color (red by default)
         prevTime = 0L;       // For animation timing
void loop(void) {
  int      c;
  uint32_t t;
  // Animation happens at about 30 frames/sec.  Rendering frames takes less
  // than that, so the idle time is used to monitor incoming serial data.
  digitalWrite(CTS_PIN, LOW); // Signal to BLE, OK to send data!
  for(;;) {
    t = micros();                            // Current time
    if((t - prevTime) >= (1000000L / FPS)) { // 1/30 sec elapsed?
      prevTime = t;
      break;                                 // Yes, go update LEDs
    }                                        // otherwise...
    if((c = ser.read()) == '!') {            // Received UART app input?
      while((c = ser.read()) < 0);           // Yes, wait for command byte
      switch(c) {
       case 'B':       // Button (Control Pad)
        if(readAndCheckCRC(255-'!'-'B', buf, 2) & (buf[1] == '1')) {
          buttonPress(buf[0]); // Handle button-press message
        break;
       case 'C':       // Color Picker
        if(readAndCheckCRC(255-'!'-'C', buf, 3)) {
          // As mentioned earlier, setBrightness() was avoided to save space.
          // Instead, results from the color picker (in buf[]) are divided
          // by 4; essentially equivalent to setBrightness(64).  This is to
          // improve battery run time (NeoPixels are still plenty bright).
          color = pixels.Color(buf[0]/4, buf[1]/4, buf[2]/4);
        break;
       case 'Q':       // Quaternion
        skipBytes(17); // 4 floats + CRC (see note below re: parsing)
        break;
       case 'A':       // Accelerometer
#if 0
        // The phone sensors are NOT used by this sketch, but this shows how
        // they might be read.  First, buf[] must be delared large enough for
        // the expected data packet (minus header & CRC) -- that's 16 bytes
        // for quaternions (above), or 12 bytes for most of the others.
        // Second, the first arg to readAndCheckCRC() must be modified to
        // match the data type (e.g. 'A' here for accelerometer).  Finally,
        // values can be directly type-converted to float by using a suitable
        // offset into buf[] (e.g. 0, 4, 8, 12) ... it's not used in this
        // example because floating-point math uses lots of RAM and code
        // space, not suitable for the space-constrained Trinket/Gemma, but
        // maybe you're using a Pro Trinket, Teensy, etc.
        if(readAndCheckCRC(255-'!'-'A', buf, 12)) {
          float x = *(float *)(&buf[0]),
                y = *(float *)(&buf[4]),
                z = *(float *)(&buf[8]);
        // In all likelihood, updates from the buttons and color picker
        // alone are infrequent enough that you could do without any mention
        // of the CTS pin in this code.  It's the extra sensors that really
        // start the firehose of data.
        break;
#endif
       case 'G':       // Gyroscope
       case 'M':       // Magnetometer
       case 'L':       // Location
        skipBytes(13); // 3 floats + CRC
  digitalWrite(CTS_PIN, HIGH); // BLE STOP!
  // Show pixels calculated on *prior* pass; this ensures more uniform timing
  pixels.show();
  // Then calculate pixels for *next* frame...
  switch(animMode) {
   case 0: // Pinwheel mode
    for(uint8_t i=0; i<NUM_LEDS/2; i++) {
      uint32_t c = 0;
      if(((animPos + i) & 7) < 2) c = color; // 4 pixels on...
      pixels.setPixelColor(   i, c);         // First eye
      pixels.setPixelColor(NUM_LEDS-1-i, c); // Second eye (flipped)
    animPos++;
    break;
   case 1: // Sparkle mode
    pixels.setPixelColor(animPos, 0);     // Erase old dot
    animPos = random(NUM_LEDS);           // Pick a new one
    pixels.setPixelColor(animPos, color); // and light it
    break;
boolean readAndCheckCRC(uint8_t sum, uint8_t *buf, uint8_t n) {
  for(int c;;) {
    while((c = ser.read()) < 0); // Wait for next byte
    if(!n--) return (c == sum);  // If CRC byte, we're done
    *buf++ = c;                  // Else store in buffer
    sum   -= c;                  // and accumulate sum
void skipBytes(uint8_t n) {
  while(n--) {
    while(ser.read() < 0);
void buttonPress(char c) {
  pixels.clear(); // Clear pixel data when switching modes (else residue)
  switch(c) {
   case '1':
    animMode = 0; // Switch to pinwheel mode
    break;
   case '2':
    animMode = 1; // Switch to sparkle mode
    break;
   case '3':
    break;
   case '4':
    break;
   case '5': // Up
    break;
   case '6': // Down
    break;
   case '7': // Left
    break;
   case '8': // Right
    break;
Below is a stand alone code for a neopixel patern, I would like to turn this into a mode on the code above.
#define PIN 6
#define NUM_LEDS 60
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
// *** REPLACE FROM HERE ***
  CylonBounce(0xff, 0, 0, 4, 10, 50);
void CylonBounce(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
  for(int i = 0; i < NUM_LEDS-EyeSize-2; i++) {
    setAll(0,0,0);
    setPixel(i, red/10, green/10, blue/10);
    for(int j = 1; j <= EyeSize; j++) {
      setPixel(i+j, red, green, blue);
    setPixel(i+EyeSize+1, red/10, green/10, blue/10);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
  for(int i = NUM_LEDS-EyeSize-2; i > 0; i--) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
// *** REPLACE TO HERE ***
void showStrip() {
 #ifdef ADAFRUIT_NEOPIXEL_H
   // NeoPixel
   strip.show();
 #endif
 #ifndef ADAFRUIT_NEOPIXEL_H
   // FastLED
   FastLED.show();
 #endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
   // NeoPixel
   strip.setPixelColor(Pixel, strip.Color(red, green, blue));
 #endif
   // FastLED
   leds[Pixel].r = red;
   leds[Pixel].g = green;
   leds[Pixel].b = blue;
 #endif
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
    setPixel(i, red, green, blue);
  showStrip();
adafruit_support_mike
Re: Bluetooth NeoPixel Goggle project
Programming LED animations is a process of developing 'frames': individual patterns of LED colors. This tutorial shows the basic idea, and has code that converts a bitmap image into a set of animation frames:
https://learn.adafruit.com/circuit-play ... -neopixels
jcafiero86
adafruit_support_mike wrote:Programming LED animations is a process of developing 'frames': individual patterns of LED colors. This tutorial shows the basic idea, and has code that converts a bitmap image into a set of animation frames:
Thank you for that information, I will be reading into it. But I alredy have the animations from other scipts that I want to use. I'm just not sure how to transplant per say the alredy scripted animation that work fine on there own into the code for this particular code from the google tutorial that uses the blue fruit connect app to switch between anomations alredy in the code.
That could be easy, or could be hard. It depends on how the code for the effects you like happens to be written.
The most effective option is to read the code and see how the effects are written. Does the code just call a single function for the whole animation, does it work one frame at a time, or does it do something else?
The code from the NeoPixel Goggles project works one frame at a time, calculating one frame ahead so the colors are ready to go the next time the pixels need an update.
In general, copy-pasting code from one pixel animation sketch to another doesn't work. In most cases, you have to translate the ideas from one display model to the other, and that requires a fairly solid understanding of the code on both sides.
