Greetings. I could use some help with a Trinket M0 on Arduino that was working fine and suddenly isn't.
Working on a nice little saturated oxygen sensor project with a Trinket M0, a 128x32 OLED screen, and an SPO2 sensor.
Uploads worked well over a couple of days until yesterday. Now I can no longer get a port and I get a "USB not recognized" error message on Windows 10.
OS: Windows 10
IDE: Arduino IDE 1.8.13
Board: Trinket M0 [confirmed 100%]
USB data cable: Confirmed and tested fine on another trinket board
What I've tried so far:
1. Disconnected cable, Trinket M0 and restarted laptop
2. Opened Arduino IDE, checked for board and library updates
3. Plugged Trinket M0 into laptop USB port, same one that works fine with other boards.
===> "USB device not recognized" error message pops up and no com port available on IDE tools menu
4. Double click reset button on Trinket M0 board gets me trinketboot folder F message, a new com port (Com 3) is now available and Dotstar goes green.
5. Uploading sketch goes through the motions with green bar, "Sketch uses 35876 bytes (13%) of storage space."
===> IDE reports "An error occurred while uploading the sketch"
Atmel SMART device 0x1001000a found
SAM-BA operation failed
Device : ATSAMD21E18A
Chip ID : 1001000a
Version : v1.1 [Arduino:XYZ] Nov 2 2018 22:53:16
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 5.011 seconds
===> Windows informs me USB device not recognized
Is there anything else I can try?
Trinket M0- USB device not recognized
- curiousSubstance3
- curiousSubstance3
Re: Trinket M0- USB device not recognized
Opened a brand new Trinket M0 today and tried loading Blink and it worked fine. Tried a simple Dotstar sketch and that worked too. Tried a third sketch and... same problem as with my first Trinket M0. Sketch uploads, it shows as complete with the memory used, but it hangs with the green bar always on screen.
Tried the new Trinket M0 on a different computer (Windows 10 again). Nothing, same problem. Tried Blink on an Arduino Nano and it works fine.
What is happening with these Trinket M0's? Any suggestions Costumer Service?
- curiousSubstance3
This is the error message when I try to compile an Arduino sketch on either Trinket M0:
Arduino: 1.9.0-beta (Windows 10), Board: "Adafruit Trinket M0, Small (-Os) (standard), Arduino, Off"
C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\hardware -hardware C:\Users\A\AppData\Local\Arduino15\packages -tools C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\tools-builder -tools C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\hardware\tools\avr -tools C:\Users\A\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\libraries -libraries C:\Users\A\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_trinket_m0:opt=small,usbstack=arduino,debug=off -ide-version=10900 -build-path C:\Users\A\AppData\Local\Temp\arduino_build_32483 -warnings=none -build-cache C:\Users\A\AppData\Local\Temp\arduino_cache_790976 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS-Atmel\1.2.1 -prefs=runtime.tools.CMSIS-Atmel-1.2.1.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS-Atmel\1.2.1 -prefs=runtime.tools.CMSIS.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.openocd.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arduinoOTA.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -verbose -experimental C:\Users\A\Documents\Arduino\Trinket_DotStar_sketch_jul06a\Trinket_DotStar_sketch_jul06a.ino
C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\arduino-builder -compile -logger=machine -hardware C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\hardware -hardware C:\Users\A\AppData\Local\Arduino15\packages -tools C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\tools-builder -tools C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\hardware\tools\avr -tools C:\Users\A\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\libraries -libraries C:\Users\A\Documents\Arduino\libraries -fqbn=adafruit:samd:adafruit_trinket_m0:opt=small,usbstack=arduino,debug=off -ide-version=10900 -build-path C:\Users\A\AppData\Local\Temp\arduino_build_32483 -warnings=none -build-cache C:\Users\A\AppData\Local\Temp\arduino_cache_790976 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS-Atmel\1.2.1 -prefs=runtime.tools.CMSIS-Atmel-1.2.1.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS-Atmel\1.2.1 -prefs=runtime.tools.CMSIS.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\CMSIS\5.4.0 -prefs=runtime.tools.openocd.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=C:\Users\A\AppData\Local\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4 -prefs=runtime.tools.arduinoOTA.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.bossac.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=C:\Users\A\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.8.0-48-gb176eee -verbose -experimental C:\Users\A\Documents\Arduino\Trinket_DotStar_sketch_jul06a\Trinket_DotStar_sketch_jul06a.ino
Using board 'adafruit_trinket_m0' from platform in folder: C:\Users\A\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.0
Using core 'arduino' from platform in folder: C:\Users\A\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.0
Detecting libraries used...
"C:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Trinket_DotStar_sketch_jul06a.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10900 -DARDUINO_TRINKET_M0 -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DADAFRUIT_TRINKET_M0 -D__SAMD21E18A__ -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x801E -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Trinket M0\"" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0/libraries/Adafruit_TinyUSB_Arduino/src/arduino" -Os -DCRYSTALLESS -DADAFRUIT_TRINKET_M0 -D__SAMD21E18A__ -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x801E -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Trinket M0\"" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0/libraries/Adafruit_TinyUSB_Arduino/src/arduino" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS-Atmel\\1.2.1/CMSIS/Device/ATMEL/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\cores\\arduino" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\variants\\trinket_m0" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\sketch\\Trinket_DotStar_sketch_jul06a.ino.cpp" -o nul
Alternatives for Adafruit_DotStar.h: [[email protected]]
ResolveLibrary(Adafruit_DotStar.h)
-> candidates: [[email protected]]
"C:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Trinket_DotStar_sketch_jul06a.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10900 -DARDUINO_TRINKET_M0 -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DADAFRUIT_TRINKET_M0 -D__SAMD21E18A__ -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x801E -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Trinket M0\"" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0/libraries/Adafruit_TinyUSB_Arduino/src/arduino" -Os -DCRYSTALLESS -DADAFRUIT_TRINKET_M0 -D__SAMD21E18A__ -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x801E -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Trinket M0\"" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0/libraries/Adafruit_TinyUSB_Arduino/src/arduino" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS-Atmel\\1.2.1/CMSIS/Device/ATMEL/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\cores\\arduino" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\variants\\trinket_m0" "-IC:\\Users\\A\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\sketch\\Trinket_DotStar_sketch_jul06a.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\A\Documents\Arduino\libraries\Adafruit_DotStar\Adafruit_DotStar.cpp
Alternatives for SPI.h: [[email protected]]
ResolveLibrary(SPI.h)
Alternatives for Adafruit_ZeroDMA.h: [[email protected] [email protected]]
ResolveLibrary(Adafruit_ZeroDMA.h)
-> candidates: [[email protected] [email protected]]
Using cached library dependencies for file: C:\Users\A\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.0\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\A\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.0\libraries\Adafruit_ZeroDMA\Adafruit_ZeroDMA.cpp
Generating function prototypes...
"C:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"Trinket_DotStar_sketch_jul06a.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10900 -DARDUINO_TRINKET_M0 -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DADAFRUIT_TRINKET_M0 -D__SAMD21E18A__ -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x801E -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Trinket M0\"" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0/libraries/Adafruit_TinyUSB_Arduino/src/arduino" -Os -DCRYSTALLESS -DADAFRUIT_TRINKET_M0 -D__SAMD21E18A__ -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x801E -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Trinket M0\"" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0/libraries/Adafruit_TinyUSB_Arduino/src/arduino" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS-Atmel\\1.2.1/CMSIS/Device/ATMEL/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\cores\\arduino" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\variants\\trinket_m0" "-IC:\\Users\\A\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\libraries\\SPI" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\libraries\\Adafruit_ZeroDMA" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\sketch\\Trinket_DotStar_sketch_jul06a.ino.cpp" -o "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\A\Downloads\arduino-1.9.0-beta-windows(1)\arduino-PR-beta1.9-BUILD-119\tools-builder\arduino-preprocessor\0.1.5/arduino-preprocessor" "C:\Users\A\AppData\Local\Temp\arduino_build_32483\preproc\ctags_target_for_gcc_minus_e.cpp" "" -- -std=gnu++11
Compiling sketch...
"C:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD "-D__SKETCH_NAME__=\"\"\"Trinket_DotStar_sketch_jul06a.ino\"\"\"" -DF_CPU=48000000L -DARDUINO=10900 -DARDUINO_TRINKET_M0 -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DADAFRUIT_TRINKET_M0 -D__SAMD21E18A__ -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x801E -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Trinket M0\"" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0/libraries/Adafruit_TinyUSB_Arduino/src/arduino" -Os -DCRYSTALLESS -DADAFRUIT_TRINKET_M0 -D__SAMD21E18A__ -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x801E -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Trinket M0\"" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0/libraries/Adafruit_TinyUSB_Arduino/src/arduino" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Core/Include/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/DSP/Include/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS-Atmel\\1.2.1/CMSIS/Device/ATMEL/" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\cores\\arduino" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\variants\\trinket_m0" "-IC:\\Users\\A\\Documents\\Arduino\\libraries\\Adafruit_DotStar" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\libraries\\SPI" "-IC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\libraries\\Adafruit_ZeroDMA" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\sketch\\Trinket_DotStar_sketch_jul06a.ino.cpp" -o "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\sketch\\Trinket_DotStar_sketch_jul06a.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit_DotStar"
Using previously compiled file: C:\Users\A\AppData\Local\Temp\arduino_build_32483\libraries\Adafruit_DotStar\Adafruit_DotStar.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\A\AppData\Local\Temp\arduino_build_32483\libraries\SPI\SPI.cpp.o
Compiling library "Adafruit_ZeroDMA"
Using previously compiled file: C:\Users\A\AppData\Local\Temp\arduino_build_32483\libraries\Adafruit_ZeroDMA\Adafruit_ZeroDMA.cpp.o
Compiling core...
Using previously compiled file: C:\Users\A\AppData\Local\Temp\arduino_build_32483\core\variant.cpp.o
Using precompiled core: C:\Users\A\AppData\Local\Temp\arduino_cache_790976\core\core_d59c57ca7badea6ce6e1b645bc026b74.a
Linking everything together...
"C:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-g++" "-LC:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483" -Os -Wl,--gc-sections -save-temps "-TC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\variants\\trinket_m0/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483/Trinket_DotStar_sketch_jul06a.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483/Trinket_DotStar_sketch_jul06a.ino.elf" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\sketch\\Trinket_DotStar_sketch_jul06a.ino.cpp.o" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\libraries\\Adafruit_DotStar\\Adafruit_DotStar.cpp.o" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\libraries\\Adafruit_ZeroDMA\\Adafruit_ZeroDMA.cpp.o" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483\\core\\variant.cpp.o" -Wl,--start-group "-LC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\CMSIS\\5.4.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math "-LC:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\hardware\\samd\\1.7.0\\variants\\trinket_m0" -lm "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483/..\\arduino_cache_790976\\core\\core_d59c57ca7badea6ce6e1b645bc026b74.a" -Wl,--end-group
c:/users/a/appdata/local/arduino15/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 8 bytes
"C:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-objcopy" -O binary "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483/Trinket_DotStar_sketch_jul06a.ino.elf" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483/Trinket_DotStar_sketch_jul06a.ino.bin"
"C:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483/Trinket_DotStar_sketch_jul06a.ino.elf" "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483/Trinket_DotStar_sketch_jul06a.ino.hex"
Multiple libraries were found for "Adafruit_ZeroDMA.h"
Used: C:\Users\A\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.0\libraries\Adafruit_ZeroDMA
Not used: C:\Users\A\Documents\Arduino\libraries\Adafruit_Zero_DMA_Library
Using library Adafruit_DotStar at version 1.1.4 in folder: C:\Users\A\Documents\Arduino\libraries\Adafruit_DotStar
Using library SPI at version 1.0 in folder: C:\Users\A\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.0\libraries\SPI
Using library Adafruit_ZeroDMA at version 1.0.4 in folder: C:\Users\A\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.7.0\libraries\Adafruit_ZeroDMA
"C:\\Users\\A\\AppData\\Local\\Arduino15\\packages\\adafruit\\tools\\arm-none-eabi-gcc\\9-2019q4/bin/arm-none-eabi-size" -A "C:\\Users\\A\\AppData\\Local\\Temp\\arduino_build_32483/Trinket_DotStar_sketch_jul06a.ino.elf"
Sketch uses 17728 bytes (6%) of program storage space. Maximum is 262144 bytes.
Compiling sketch...
Compiling core...
- miktek1
Too bad there is not a reply here from the moderator as I am having almost exactly the same issue with my new Trinket MO.
Uploads will not complete. The trinket was recognized on my com port 6 but now I can no longer get a port and I get a "USB not recognized" error message on Windows 10.
OS: Windows 10
IDE: Arduino IDE 1.8.15
Board: Trinket M0
USB data cable: Confirmed it is a data cable not just power.
The error upon trying to upload:
Sketch uses 4824 bytes (1%) of program storage space. Maximum is 262144 bytes.
Chip ID : 1001000a
Address : 8192
Pages : 3968
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Erase flash
done in 0.846 seconds
Write 4848 bytes to flash (76 pages)
[==============================] 100% (76/76 pages)
done in 0.049 seconds
Verify 4848 bytes of flash with checksum.
Verify successful
done in 0.008 seconds
CPU reset.
The above is in red
Any help appreciated
Mike
OS: Windows 10
Board: Trinket M0
Chip ID : 1001000a
Address : 8192
Pages : 3968
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Erase flash
Verify successful
CPU reset.
The above is in red
Mike
- Franklin97355
What are you placing the Trinket on? Make sure you have a nonconductive surface and plug the board in when the power is off.
- adafruit_support_carter
@miktek1 Your upload looks normal.
@curiousSubstance3 You've got a mix of things going on. New boards and used boards. Multiple PC's being used. Multiple Arduino IDE versions being used. As a starting point, do you have a new Trinket M0 that you can still reliably get into bootloader mode? That is, double press the reset button and get the TRINKETBOOT folder to show up?
