Trinket M0 Pinout: AIN18/13
cerniuk
Post by cerniuk »
I am under the impression from the pinout legend that AIN18, cross-referenced as 13, as an Analog Input. My initial assumption is that this is one of the diode pads. One is ground and the other is the high potential side of the diode, neither of which seem like a proper input. Could you advise on which SMD pad is intended as this input?
adafruit_support_carter
Re: Trinket M0 Pinout: AIN18/13
You can get schematics and Eagle CAD files here:
https://learn.adafruit.com/adafruit-tri ... /downloads
which will show all the details. In general, that pin is not broken out for external use.
