Hi
I have a new Adafruit Trinket - Mini Microcontroller - 5V
First what card to chose? see attached pic
Second: I get Error when uploading
I have run drivers installation, I have USBtiny in devices, have tryed different usb ports and cables.
Arduino:1.8.15 (Windows Store 1.8.49.0) (Windows 10), Kort:"Adafruit Trinket (ATtiny85 @ 8MHz)"
Sketch uses 696 bytes (13%) of program storage space. Maximum is 5310 bytes.
Global variables use 9 bytes of dynamic memory.
Ett fel inträffade under uppladdning av sketchen = Error when uploading the sketch
Error uploading sketch to Trinket
- Orix
- Attachments
- Trinket Card.png (15.34 KiB) Viewed 315 times
- preferences.txt
- (5.21 KiB) Downloaded 7 times
- adafruit_support_carter
Re: Error uploading sketch to Trinket
Try the 8MHz option to see if it helps. Using 16MHz requires some additional steps:
https://learn.adafruit.com/introducing- ... 8mhz-clock
But also - the Trinket 5V is a deprecated board. See warning at top of product page:
https://www.adafruit.com/product/1501
You can try a USB 2.0 hub and see if that helps. But it may just be that your PC won't be able to upload to it.
- Orix
Sad to hear.
The swedish dealer had no warning!
I now put the 8$ part in the garbage and send them a mail.
- adafruit2
ask them to replace it with a trinket m0, it may work better for you.
