Non-standard clock rate for Pro Trinket detected
Adafruit's tiny microcontroller platform. Please tell us which board you are using.
Gamerto1212
Post by Gamerto1212 »
I ordered 3 Adafruit trinkets M0's, and started to make little projects. Im not verry setteld with micro controllers, but i have an idea how they work and what you need. So, i was making this: https://learn.adafruit.com/trinket-usb-volume-knob/code
I did the wiring, installed the librarys, selected the correct board in the Ardunio IDE, and copied the code into the IDE. some libraries are twice included, i will get rid of duplicates later. how erver, i trid to compile / verify the code, and it gave me this error:
In file included from C:\Users\William\Documents\Arduino\sketch_jun12a\sketch_jun12a.ino:3:
C:\Users\William\Documents\Arduino\libraries\Pro_Trinket_USB_Keyboard_Library/usbconfig.h:59:2: error: #error "Non-standard clock rate for Pro Trinket detected"
59 | #error "Non-standard clock rate for Pro Trinket detected"
I dont know why it says for Pro Trinket, but with this error i cant load the program on the Trinket. I did some research, but i couldnt find anything that helped me. So now im asking people who are more into this and are able to help me. If i should add any information, just comment it and i will try to provide ist ASAP.
Thanks for your efforts.
dastels
Re: Non-standard clock rate for Pro Trinket detected
Post by dastels »
That project uses the "Pro Trinket USB Keyboard Library" which, as the name says, is for the Pro Trinket... not the Trinket M0.
Have a look at https://learn.adafruit.com/media-dial for a comparable project using the Trinket M0.
Gamerto1212
Thank you very much for the reply. i will try the one you linked
Return to “Trinket ATTiny, Trinket M0”
