Update:
I was able to find and flash the current bootloader:
Issue resolved. Sorry for the noise.
Original message:
No thinking through everything, I managed to update the boot loader on 9 out of 10 of my Trinkey M0 devices, I can get into the boot loader, with double click, I can load circuit python no issues, but there must be some check in circuit python that enables the internal modules based on what it sees in the bootloader, is there a UF2 bootloader file for the Trinkey M0 that I can reload on the keys?
They came with:
UF2 Bootloader v1.23.1-adafruit.1-337-g1c691d5 SFHWRO
Model: NeoPixel Trinkey M0
Board-ID: SAMD21E18A-NeoTrinkey-v0
I have managed to load:
UF2 Bootloader v3.13.0 SFHWRO
Model: Trinket M0
Board-ID: SAMD21E18A-Trinket-v0
Thanks in advance.
Upgraded to bootloader breaks Trinkey M0
- Franklin97355
Re: Upgraded to bootloader breaks Trinkey M0
So, you're OK now? Not sure if you got it fixed.
- techman
Yes, the issue is resolved.franklin97355 wrote:So, you're OK now? Not sure if you got it fixed.
Silly mistake on my part, once I found the correct bootloader I was able to fix it pretty quickly.
thank you.
