I'm trying to use the Adafruit NeoPixel Library (with the Attiny-Core) with an Attiny85-20PU to drive a sk6812 strip with 144 Leds. When using an arduino Uno it works fine with any number of LEDs, but when I use the tiny, if I specify more than 78 LEDs nothing happens. Is there some inherent limitation of the chip - like limited memory - that's preventing it from working? Or, might it have something to do with the library? Thanks!
Num LEDs limited to 78 when using ATtiny85
- dastels
Re: Num LEDs limited to 78 when using ATtiny85
Yes, it only has 512 bytes of RAM... that's half a K. At 3 bytes per NeoPixel. Conceivably you could fit a buffer for 170 pixels... but you have other things using RAM as well. My guess is that when the code tries to allocate the NeoPixel buffer it can't. When that happens, the library happily sets things to use no pixels. It doesn't crash... it just doesn't control any pixels.
The MCU in the UNO is an ATmega328P that has 2K of ram... 4 times as much.
