Trinket M0 not resetting
- rushabh11shah
I am trying to reset my trinket m0 device by putting it in the bootloader mode and then dragging the .uf2 circuit python file into the trinketboot. However, the moment the file touches the bootlader icon (i have only dragged it and not dropped it), the file manager stops responding and that cascades into my laptop not working. I am using windows 10. I have also tried using the erase file. This doesn't cause my laptop to stop working but when the progress bar for how much has been copied shows up, it just stays at 0%.
- mikeysklar
Re: Trinket M0 not resetting
This sounds like a possible USB port or data cable that is not able to keep up with the transfer.
If you have another cable and port you can try that would eliminate those possibilities.
Another option to try is to use upload the .bin file using bossac.
https://learn.adafruit.com/welcome-to-c ... stallation
If you have not uploaded your trinket M0 to the latest bootloder that might be something to try before updating the CircuitPython.
https://circuitpython.org/board/trinket_m0/
- adafruit_support_carter
Also see here for some known issues that can happen with various 3rd party software like antivirus:
https://learn.adafruit.com/welcome-to-c ... leshooting
