I just received a handful of Trinket M0 boards and noticed they were running CircuitPython 3.x. So I flashed them with CircuitPython 6.3.0.
I see the CIRCUITPY in the my Mac Finder after the upgrade. I can connect to the serial console using the Mac terminal and `screen` and running a `print("hello world")` statement works and outputs to the console. But using Mu, and writing a script for the board does not.
Even using the example script to blink the DotStar LED is not working. All I see when I save in Mu is the DotStar flash very very quickly once.
Any ideas? I have 4 boards. One i upgraded to CircuitPython 6.3.0 and the other I left at CircuitPython 3.x. Neither work with Mu.
Mac OSX 10.13.6
Mu Python 3.8
Mac OSX installed Python 3.6
No errors in Mu logs
Trinket m0 not executing python changes from Mu
- rfender
- Franklin97355
Re: Trinket m0 not executing python changes from Mu
What file name are you loading?
- rfender
@franklin97355, I was upgrading to circuitpython 6.x.x using `adafruit-circuitpython-trinket_m0-en_US-6.3.0.uf2`.
As a work around, I transitioned to using VS Code as the editor with the circuitpython extension. This seems to work. I can write code, download it to the trinket and run it but I experience other issues which I will post in another topic thread.
Regardless, I flashed with the file I put above
