Hi, I am working on the Zelda sword project with my son. We are trying to compile the code in Ardunio. I am running windows 10 and it is seeing the trinket connected
We are getting the following error:
Multiple libraries were found for "Adafruit_NeoPixel.h"
Used: C:\Program Files (x86)\Arduino\libraries\Adafruit_NeoPixel
Not used: C:\Program Files (x86)\Arduino\libraries\Adafruit_NeoPixel
Sketch uses 11,092 bytes (4%) of program storage space. Maximum is 262,144 bytes.
java.io.IOException: Cannot run program "{runtime.tools.bossac-1.7.0-arduino3.path}/bossac.exe": CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:115)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:160)
at processing.app.debug.Compiler.upload(Compiler.java:163)
at processing.app.Sketch.upload(Sketch.java:1220)
at processing.app.Sketch.exportApplet(Sketch.java:1194)
at processing.app.Sketch.exportApplet(Sketch.java:1166)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2487)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 9 more
Problems using
- adafruit_support_carter
Re: Problems using
Just to be sure, this is the project guide you are following?
https://learn.adafruit.com/breath-of-th ... d/overview
As a basic check of your Arduino setup, try running this blink example:
and see if you can get that to upload and run successfully on the Trinket.
- mathyou1000
Re: Problems using
Hi Thank you, The real issue is getting Arduino working with the board on my PC. I can make Mu work with the trinket but I can not upload with Arduino. I have enclosed the full error code below (at the bottom of the post) for your review. Is it possible for me to get the code for the trinket for the Zelda guardian sword as below?:
******************************************CODE**********************************************************
#ifdef __AVR__
#include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN 4
// Color Segments
#define APIXELS 14 // number of first orange pixels
#define BPIXELS 84 // number of blue pixels
#define CPIXELS 93 // second orange pixels
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(93, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 10; // delay for half a second
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (__AVR_ATtiny85__)
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
// End of trinket special code
pixels.begin(); // This initializes the NeoPixel library.
// For the first 14 pixels, make them orange, starting from pixel number 0.
for(int i=0;i<APIXELS;i++){
pixels.setPixelColor(i, pixels.Color(255,50,0)); // Set Pixels to Orange Color
pixels.show(); // This sends the updated pixel color to the hardware.
delay(delayval); // Delay for a period of time (in milliseconds).
// Fill up 84 pixels with blue, starting with pixel number 14.
for(int i=14;i<BPIXELS;i++){
pixels.setPixelColor(i, pixels.Color(0,250,200)); // Set Pixels to Blue Color
// Fill up 9 pixels with orange, starting from pixel number 84.
for(int i=84;i<CPIXELS;i++){
pixels.setPixelColor(i, pixels.Color(250,50,0)); //Set Pixels to Orange Color
********************END of CODE**************************************
********************ERROR MESSAGE*********************************
C:\Users\cycle\AppData\Roaming\Arduino15\packages\adafruit\tools\arm-none-eabi-gcc\9-2019q4/bin/arm-none-eabi-objcopy -O ihex -R .eeprom C:\Users\cycle\AppData\Local\Temp\build5177472080559358608.tmp/Blink.cpp.elf C:\Users\cycle\AppData\Local\Temp\build5177472080559358608.tmp/Blink.cpp.hex
Sketch uses 4,812 bytes (1%) of program storage space. Maximum is 262,144 bytes.
Forcing reset using 1200bps open/close on port COM3
PORTS {COM3, } / {} => {}
PORTS {} / {COM4, } => {COM4, }
Found upload port: COM4
{runtime.tools.bossac-1.7.0-arduino3.path}/bossac.exe -i -d --port=COM4 -U true -i -e -w -v C:\Users\cycle\AppData\Local\Temp\build5177472080559358608.tmp/Blink.cpp.bin -R
... 9 more
#ifdef __AVR__
#endif
#define PIN 4
// Color Segments
#endif
... 9 more
Re: Problems using
Are you running Mu and Arduino at the same time? It may be that there's a conflict between programs accessing the serial port.
