Proximity Trinkey Code reset
TechAaron
Post by TechAaron »
I accidentally left my Proximity Trinkey plugged in and wrote over the default code for it, and I'm not sure how to load code back onto it, as I would like to return it to its original functionality. I have installed both SAMD libraries, and tried loading code via bootloader (as the key wont respond otherwise) but I can't seem to get it working. I assume I've got the wrong settings in the Arduino IDE (ie TinyUSB compilers or other bootloaders) but I could use some direction, and if possible the default code that was run on the device when it was sent to me.
I have been working under the assumption that it is to be treated like a Trinket M0, but perhaps that is incorrect.
Thank you.
adafruit_support_carter
Re: Proximity Trinkey Code reset
Try again using "Adafruit ProxLight Trinkey (SAMD21)" as the board. Should be in the Adafruit SAMD board list.
Tools->Board->Adafruit SAMD->Adafruit ProxLight Trinkey (SAMD21)
TechAaron
Post by TechAaron »
Thank you for the reply I managed to get that far yesterday, and was able to upload code, but I wasn't able to get any feedback from the device as I couldn't find any documentation for the pinout. Is there any information on that, or any way to get a copy of the code that comes preloaded onto it?
Yep, there's a guide in works. Should be out soon. That'll have all that info.
TechAaron
Post by TechAaron »
Great! I'll wait for the guide. Thank you for the help.
