Edit* tft 2.4" cap touch
I'm trying to get the pi 3 to connect to the tft 2.4"call touch. The install command on this site don't work. I get not found errors. I could use a little help here.
Pip boy
- mikeysklar
Re: Pip boy
When you run our install script with the following command and reboot do you get anything on the display? Are you running the current Pi OS release with updates installed?
https://learn.adafruit.com/adafruit-2-4 ... sy-install
sudo python3 adafruit-pitft.py --display=28r --rotation=90 --install-type=console
- Dumbles02
Re: Pip boy
Ok it works. But it still boots to the TV. I have text on the tft, and desktop on the TV. Dunno what's wrong
- mikeysklar
Re: Pip boy
What setup are you hoping to have in the end?
You can have graphical X-windows on the TFT and TV (monitor?) output as well if you prefer.
- Dumbles02
Re: Pip boy
I took about 4 hours before I realized I was pressing the yes to the wrong option... Smh
