New to any type of programming, I was wondering if anyone can tell me why I cant get the second half of this code to run (lines 14-23). Any help would be appreciated and if anyone has any suggestions to the best place to learn more.
Help with code. Adafruit Trinket MO
- JKracht
- Attachments
- Light Circuit.py
- (437 Bytes) Downloaded 11 times
- adafruit_support_carter
Re: Help with code. Adafruit Trinket MO
You have two infinite loops. Only the first one is being run:
Nothing after that is ever reached.
while True:
led.value = True
time.sleep(2.0)
led.value = False
time.sleep()
- JKracht
How do I stop the infinite loop?
You can stop the entire code from running by using <CTRL><C>, but that's probably not what you are after.
What are you trying to get the code to do?
- JKracht
I'm trying to get the code to run function 1
while True:
led.value = True
time.sleep(2.0)
led.value = False
time.sleep()
then stop and then just run the second part, after the first one has shut off
while True:
led.value = False
time.sleep(3.0)
led.value = True
time.sleep(1.0)
led.value = False
time.sleep()
basically to just control a relay and shut off then control a second one and shut off.
while True:
led.value = True
time.sleep(2.0)
led.value = False
time.sleep()
while True:
led.value = False
time.sleep(3.0)
led.value = True
time.sleep(1.0)
led.value = False
time.sleep()
You want those actions to happen only once?
Then the loops probably are not needed.
What determines when the first one has shut off? Do you need to wait for something before the second part is run? Or can the second part run immediately after the first?then stop and then just run the second part, after the first one has shut off
