Adafruit Trinket M0 Footswitch not working
- bratan808
Hello guys, I purchased an adafruit Trinket M0 and i basically copypasted the code mentionend in the video made by adafruit (https://www.youtube.com/watch?v=gzG1hSg30aY), but nothing seems to happen. I am not sure what I am doing wrong as even the switch I am using is the same switch which is used in the video.. The Trinket M0 is starting and the pink and green LEDs are lightubg up but it is not working. The file is named main.py . You can also see two photos, but I do not think my soldering has shorted anything out, as I cannot see anything that would indicate such a problem.
- WhatsApp Image 2021-10-09 at 13.59.56.jpeg (174.45 KiB) Viewed 343 times
- WhatsApp Image 2021-10-09 at 13.59.45.jpeg (217.29 KiB) Viewed 343 times
- dastels
Re: Adafruit Trinket M0 Footswitch not working
I do see bare wires, which is never a good thing. The soldering on the trinket pins looks globby, but doesn't appear to be shorting on the other pins.
Can you post the code? Also, make sure there isn't any other files named code or main.... just your main.py.
