I have used the "Playground" and most recently several programs for the Raspberry Pi Pico (what a great board that is!). One is running a stepping motor very nicely. It uses only one digital output! So i want to miniaturize my system, so have a "Trinket MO" that is lighting an on-board LED in many colors (it came this way). I have no idea how to program it. Do I use Aduino? How can i see the resident program to give me a lesson as to writing my own?
Hope the question is not too naive.
Bob
Trinket Mo Beginner
- dastels
Re: Trinket Mo Beginner
You can use either Arduino/C++, Makecode, or CircuitPython to program it (and others, but those are the main ones). See https://learn.adafruit.com/adafruit-tri ... on-arduino for the details.
When you plug in the USB cable, does a CIRCUITPY drive pop up on your computer? If so look in there for a file named code.py. That's the CircuitPython program that's running.
- rbdopp
Thank you! Yes, the Trinket is in the Finder and I am moving forward!
- rbdopp
My first trinket worked great controlling my stepping motor. Then i powered it on 12 volts (to pin "Bat") and it gave a puff of smoke and died. Oh well, so I bought two more. When I usb either of them into my iMac, the "CIRCUITPY drive" does not appear - in brand new Trinkets! In both, the green LED comes on and the red for a few seconds very dimly. Is there some sort of activation or bundle loading I need to do? I wonder why the first one behaved the way you suggested it should (with the drive appearing)?
As a side note, to make the stepping motor (on 16x mode, so 3200 poles) run at exactly 1 rpm (on a 24 hour test) required a 1.2% delay added to the sleep portion. It makes sense since the clock aint an atomic clock!
- dastels
Yes. From the pinouts section of the guide:
Then try upgrading the bootloaders (See https://learn.adafruit.com/adafruit-tri ... 2929771-34) with the latest version from https://github.com/adafruit/uf2-samdx1/ ... ag/v3.13.0. Currently that will be bootloader-trinket_m0-v3.13.0.bin.
First, confirm that your USB cable is data and not just a charge/power cable.BAT - This is a voltage INPUT pin, you can use it to connect a battery or other external power to the Trinket. It has a Schottkey protection diode so it is completely separate from the USB power input/output. You can put 3V-6V into this pin and it will be regulated down by the 3V regulator
- rbdopp
Dear Dave,
I REALLY appreciate you helping me on this.
In the 80’s and 90’s I was a high-powered programmer in Assembly, Pascal and then in Basic structured like Pascal with subroutines in Machine language for voltages, times and curser locations at RAYOVAC in Madison WI. Then I stopped programming.... I am getting back into it and loving it (and frustrates by it). We are two old-farts with 7 Macs and 2 Windows machines (for the Lab, which needs Windows for the equipment). This new hobby of Trinkets, Pico’s and the like is very exciting and also somewhat frustrating. I will let you know how it goes.
Appreciatively,
Bob
Appreciatively,
Bob
- rbdopp
Evening Dave,
I checked my USB’s and they are data ready. I used my Kindle and could see the directory in it from the cable.
I tried the link, but without “seeing” the device, no new upgrade could be loaded.
Since the first Trinket worked as you told me to see the drive on my finder, I wonder if these two are somehow faulty. When I plug them in, the green LED light goes on immediately, the red LED is dim for about half a second, then there are 23 bright red LED blinks. After that, only the green Led is lighted. Is that a clue?
Perhaps these are defective Trinkets. Who knows who I purchased them from on Amazon.
The clock runs perfectly! Is a bit noisy, but so cool.
Smiling,
Bob
Smiling,
Bob
- rbdopp
I hate to be a pest... but i just can not figure out how to load the “USBtinyISP” on my trinket. In Arduino, it is not listed in the "tools/board" set. I know know what the flashing means (slapping my forehead) so can get in boot loading mode, but is there another way to load the USBtinyISP?
- rbdopp
Problem understood. Item is obsolete since 2014. Ain't ever gonna work. Loved the tiny size. Shoot.
