Help needed please!
mariomillerjr
Help needed please!
Post by mariomillerjr »
Hello every one. I’m not sure if I’m even posting this in the right section, but I’m fairly new to all of this. For my project I have two LED’s that I want connected to the same power source, but I want each one to be activated by its own switch. It’s for a nerf Stryfe blaster mod. I’ll have one LED that’s activated by a lever switch when the magazine is inserted and another LED that’s activated by a Hall effect sensor to indicate when the darts have run out. I want them to be connected to the same power source.. how can I go about doing this as simple and compact as possible?
Re: Help needed please!
Connect each anode to your positive power supply via a current limiting resistor.
Connect the cathode of one to ground via the lever switch.
Connect the cathode of the other to the output of your Hall sensor.
dastels
Post by dastels »
First, read this if you haven't yet: https://learn.adafruit.com/all-about-leds.
Now to use the LEDs in your situation.
Slightly different from Bill's response, but electrically equivalent. The main point is that you have two circuits of a LED, a resistor, and a switch between the positive and ground of your power source.
Connect the anode (the positive side) of each LED to the + side of your power source. Connect a resistor to the cathode (negative side) of each LED to one side of a resistor (each LED will need it's own resistor, the value of which will depend on the voltage of your power source and the LED). Connect the other side of each resistor to one side of one of the switches and the other side of each switch to the ground (negative) side of the power source. Now activating the switches will light the associated LED.
mariomillerjr
. Each LED is 3 volts, so I have them connected to a 6 volt power source. While I have you here, what resistor would you recommend for that? honestly, I’ve always had trouble when using resistors as I find it a bit confusing lol.
dastels
Post by dastels »
It's explained in the guide I linked to.
mariomillerjr
In this case what exactly is the job of the resistor and how does wiring them up make the circuit work the way I’d like it to?
mariomillerjr
Is there a way to do it without using resistors?
You need something to limit the current through the LED to avoid damage. A resistor is the simplest way to do it. And there are dozens of easy-to-use resistor calculators on-line:
Here is one: https://www.make-it.ca/led-dropping-res ... alculator/
dastels
Post by dastels »
You could use a power source that's the same as the forward voltage of the LEDs. The Resistor serves to "absorb" the excess voltage at the current required by the LED.
mariomillerjr
I really appreciate all the help! Here’s another question? Is it possible to code and program this with a trinket? Or if not a trinket, something else?
