I'm running a strip of 77 DotStars with a Trinket M0 and really want to use pin 2 for the clock and pin 0 for data but it doesn't seem to work. Using pin 2 for clock and pin 4 for data works great but switching data to pin 0 does not. I know pin 1 won't work for PWM, but 0 should work according to the docs. I'm initializing the strip with
Adafruit_DotStar strip2 = Adafruit_DotStar(NUMSTRIP, 0, 2, DOTSTAR_BGR);
but the strip stays dark, then goes white. If I use 4 instead of 0 it works fine. Any insight would be helpful. I know pin 0 on this board works because if I use it as a touch trigger it works fine.
Question about pins for driving a DotStar strip
- JeffMThomas
- JeffMThomas
Re: Question about pins for driving a DotStar strip
Ok, so apparently pin 1 does work for driving the DotStars but 0 does not. Maybe the documentation was wrong?
- adafruit_support_carter
Could be something else. I just connected a Dotstar strip to a Trinket M0 and this example worked:
Try running that and see if you can at least get the first 3 pixels to light up.
#include <Adafruit_DotStar.h>
#define NUMPIXELS 3
#define DATAPIN 0
#define CLOCKPIN 2
Adafruit_DotStar strip(NUMPIXELS, DATAPIN, CLOCKPIN, DOTSTAR_BRG);
strip.begin();
strip.fill(0xADAF00);
strip.show();
