Hi everybody,
I plan on using an Adafruit Trinket M0 as an HID over USB with a Raspberry Pi Zero 2 W.
The display I'm using with the Pi takes up all its GPIO pins so this is one option to still be able to connect a couple of buttons to the Pi, if I can get it to work.
Is it possible to connect the Trinket to the Pi over USB but power it from somewhere else?
As I understand, the Raspberry Pi Zero 2 W has one powered and one data micro USB port. The powered one is taken to power the Pi and I don't know if the other one is able to power the Trinket.
Regards.
Connect Trinket M0 to Raspberry Pi Zero 2 W?
- diff_arch
- dastels
Re: Connect Trinket M0 to Raspberry Pi Zero 2 W?
I would try powering from the Pi first. A Trinket M0 won't take much power with nothing but buttons connected. However, you can make a data-only cable or adapter (the two data lines and ground... just no 5v connection) by either cutting the 5v line in a USB cable, or making an adapter using DIY USB connectors (either a microUSB adapter (no 5v connection) or a USB-A->microUSB cable (again, with no 5v connection). See https://www.adafruit.com/?q=USB&sort=BestMatch to find the USB bits & pieces.
- diff_arch
Thank you for the reply, Dave. I'll try what you suggested, once I receive the Trinket and DIY USB connector gear.
