Rotary Trinkey
Fishe
Rotary Trinkey
Post by Fishe »
I purchased 5 Rotary Trinkeys in the hope of ganging them up to control volume by Windows application. I do not know if this is possible and my coding skills are minimal. I there a way to modify the Arduino code for the volume control to control by application instead of windows wide control?
mikeysklar
Re: Rotary Trinkey
Post by mikeysklar »
@Fishe,
You could use in-app volume control keycodes, but you will be to be selected on the app.
We do have a CircuitPython example of controlling YouTube position, but you have to be selected on youtube and the rotary encoder will send ',' or '.' to scroll through the video.
"""Rotary Trinkey YouTube Frame-by-Frame Example"""
import time
import rotaryio
import board
import digitalio
import usb_hid
from adafruit_hid.keyboard import Keyboard
from adafruit_hid.keyboard_layout_us import KeyboardLayoutUS
print("Rotary Trinkey YouTube Frame-by-Frame example")
encoder = rotaryio.IncrementalEncoder(board.ROTA, board.ROTB)
switch = digitalio.DigitalInOut(board.SWITCH)
switch.switch_to_input(pull=digitalio.Pull.DOWN)
time.sleep(1)  # Sleep for a bit to avoid a race condition on some systems
keyboard = Keyboard(usb_hid.devices)
keyboard_layout = KeyboardLayoutUS(keyboard)  # We're in the US :)
switch_state = None
last_position = encoder.position
while True:
    current_position = encoder.position
    position_change = current_position - last_position
    if position_change > 0:
        for _ in range(position_change):
            keyboard_layout.write('.')
        print(current_position)
    elif position_change < 0:
        for _ in range(-position_change):
            keyboard_layout.write(',')
    last_position = current_position
    if not switch.value and switch_state is None:
        switch_state = "pressed"
    if switch.value and switch_state == "pressed":
        print("switch pressed.")
        keyboard_layout.write(' ')
        switch_state = None
Fishe
Re: Rotary Trinkey
Post by Fishe »
Let me clarify, I am looking to control volume in app individually, like chrome, discord, iRacing and Master while in a game. There is this https://github.com/omriharel/deej which I am trying
mikeysklar
Re: Rotary Trinkey
The deej repo you found look exactly like the individual app control you desire. Were you able to install it and get it running with the rotary trinkey?
Fishe
Re: Rotary Trinkey
Post by Fishe »
I am not that smart, was hoping rather was a variation of the three command “Media_volume” whereas you could call the application. I am going to build the Deej first then move over to the trinkey
Christopher37
Re: Rotary Trinkey
Post by Christopher37 »
Since the Deej program that runs on your computer seems to just be looking for a string of "|" pipe separated values, anything that can create a serial connection and send a string of values should be able to the control the Deej program.
You could use the rotary encoder to move a number between 0 and 1023 for sending to the Deej program; but it looks like with the Rotary Trinkey you would need to have 5 USB ports to plug them into and an even bigger problem is it looks like the Deej program expects a single string of values from only a single COM port.
You would be better served with something like an Adafruit QT Py board ( https://www.adafruit.com/product/4600 ) and 5 STEMMA QT Adafruit I2C QT Rotary Encoders ( https://www.adafruit.com/product/4991 ). You would then still need to write the code to use the rotary encoders to modify values and send the string over the serial port.
Fishe
Re: Rotary Trinkey
Post by Fishe »
Thank you, I didn’t see this till just now. That is pretty much what I have found and like the Stemma route the best
Fishe
Re: Rotary Trinkey
Post by Fishe »
Can I store the Deej Client on a board and have it install to a computer
Fishe
Re: Rotary Trinkey
Post by Fishe »
I went with the QT PY and 5 breakout boards for the rotary encoder. I am seeing a problem noted in the forum regarding the turning of the know decreases the value instead of increasing. Also, it posts that the button was pressed.
At this point I am using the base arduino example.
Fishe
Re: Rotary Trinkey
Post by Fishe »
Fixed the negative
Serial.println(-new_position); // display new position (-)
