Quite possible. ISP is for low level programming. I've used it to burn the bootloader into black ATMega328 chips.
Can't reprogram Trinket
- dbetz
Re: Can't reprogram Trinket
I definitely must have trashed the bootloader since the red LED doesn't do anything when I press reset. How do I re-flash it? Just using the "Burn boot loader" option in the Arduino IDE doesn't seem to work.
- dastels
- dbetz
I saw that but I was hoping there was a way to do it with the AVRISP mkII directly rather than having to wire up an Arduino UNO. Surely an Atmel programmer can write the boot loader.
- dastels
Agreed. I assume any ISCP programmer could.
- dbetz
Is an ISCP programmer different from an ISP programmer?
- dastels
No.. and I have it wrong as well. It's an ICSP connector. In any case it's that 2x3 header on an Arduino UNO (and the like). SPI connector for low level programming.
- dbetz
That's what the AVRISP mkII has. I'm going to see if I can find the source code for that Arduino app that flashes the boot loader to see if I can extract the boot loader code from it. Or maybe I'll just bite the bullet and dig out an Arduino to use the code as is. I'm a little confused about why the Arduino IDE overwrote the boot loader when I used it to program my sketch though. It should only have written to the application area.
- dastels
The Trinket's bootloader isn't protect from overwriting... it's a pretty simplistic MCU. And ICSP is for flashing at thgat level... i.e. flashing the bootloader.
- dbetz
I broke down and used an Arduino Uno to reflash the boot loader and I'm now able to use the AVRISP mkII to program new sketches into the Trinket. My ornament is now working and my Christmas tree is still up so there is still time to enjoy it. Thanks for your help! I've attached the code in case anyone is interested. It uses a 16 LED NeoPixel ring.
[The extension ino has been deactivated and can no longer be displayed.]
- dastels
That is great to hear!
