I havent done much with the coding aspect of this at all.
What I am trying to do it use a Trinket M0 (or other board IE Gemma) to add some color choices to a wearable.
I would like to set it so that I can put a few different choice colors or patterns associated with the Neopixels so I wont need to use an external program source, or just get random colors/ loops going through the neopixels.
Any advice would be appreciated
Mini 8-Way Rotary Selector Switch neopixel colors
- Maker4091
- XRAD
Re: Mini 8-Way Rotary Selector Switch neopixel colors
one option: use the on board touch sensor to rotate through choices. Tested and works.
or just a simple button press counter....or a motion sensor....etc...some of the other adafruit boards provide more on board options
// touch - Capacitive touch demo using FreeTouch. Trinket M0 version. uses trinket pin 1
#include "Adafruit_FreeTouch.h"
Adafruit_FreeTouch qt_1 = Adafruit_FreeTouch(A0, OVERSAMPLE_4, RESISTOR_50K, FREQ_MODE_NONE);
void setup()
// Initialize A0 as a touch sensor
if (! qt_1.begin())
Serial.println("Failed to begin qt on pin A0");
void loop()
int counter, result = 0;
counter = millis();
result = qt_1.measure();
Serial.print("QT 1: "); Serial.print(result);
Serial.print(" ("); Serial.print(millis() - counter); Serial.println(" ms)");
Serial.println("\n*************************************");
delay(200);
