at the Productpage of the Adafruit Pro Trinket - 3V 12MHz is written "The Pro Trinket bit-bang USB technique it uses doesn't work as well as it did in 2014, many modern computers won't work well"
My question is, which one should I use now for the flame project?
Thank you!
Animated Flame with other Controller
- adafruit_support_bill
Re: Animated Flame with other Controller
You could use the ItsyBitsy 32U4: https://www.adafruit.com/product/3675
- KaMeCache
Thank you for the fast reply.
It has only 8 MHz and not 12 like the Trinket, is this enough?
Are you doing Phil Burgess's Animated Flame Pendant? https://learn.adafruit.com/animated-flame-pendant
Speed should not be too much of an issue since there is idle time between frames. However looking closer at the code, the processor powers down between frames. And the code to do that is pretty specific to the Atmega328p processor. You could probably hack it to work with the 32U4 which is in the same processor family. But it would be easier to stick with an Atmega328p-based board.
Your best bet is probably the Metro Mini 328 which runs at 16MHz. https://www.adafruit.com/product/2590
- KaMeCache
Yes thats the project.
I did only arduino and esp8266 projects with arduino ide an, till today.
I would like to do this project by only copy the code to the controller.
The code should work without changes on the Metro Mini 328.
- KaMeCache
Thank you for ultra fast reply, again.
Is there any possibility to use a 3.3v controller? i would like to use and lipo 3,7V battery and loading controller as well ...
That i just replace the controller from the list of the project.
There is the Feather 328P here: https://www.adafruit.com/product/3458
That is an 8 MHz board. You may need to slow down the i2c bus as noted in the guide:
It runs equally well on a 3V or 5V Pro Trinket…if you already have a 5V Pro Trinket around, that’s fine and you can use it…the 3V board is just a tiny bit more power-efficient and the battery will last a little longer. You may need to remove the part where we change I2C speed to 400 KHz but only do that if 400 KHz doesn't work on the Trinket 3.3V!
- KaMeCache
Thank you, i will try.
