Hi everyone,
I am posting inside Trinket group, but I want to ask regarding Gemma M0.
How to turn off the built-in LED DOTSTAR.
I am using Arduino IDE.
Turn off built-in DOTSTAR LED
- dastels
Re: Turn off built-in DOTSTAR LED
For how to control dotstars see https://learn.adafruit.com/adafruit-dotstar-leds. For the pins to use on the GemmaM0 see https://learn.adafruit.com/assets/49776.
Then just set it to black (i.e. #000000).
- hatem0
These links were informative, but still I am not able to turn the built-in DOTSTAR OFF.dastels wrote:For how to control dotstars see https://learn.adafruit.com/adafruit-dotstar-leds. For the pins to use on the GemmaM0 see https://learn.adafruit.com/assets/49776.
It should be easy, but I feel shy that I can't make it works.
the DOTSTAR always showing magenta, whatever color combination I use.
#include <Adafruit_DotStar.h>
#include <avr/power.h>
#define NUMPIXELS 1
Adafruit_DotStar strip(NUMPIXELS, DOTSTAR_BRG);
uint32_t color = 0x000000;
void setup()
strip.begin();
void loop()
strip.setPixelColor(0, color);
strip.show();
- dastels
You're not specifying the pins for the builtin DotStar. Clock is on digital pin 4, and data is digital pin 3. E.g.:
Adafruit_DotStar strip(NUMPIXELS, DATAPIN, CLOCKPIN, DOTSTAR_BRG);
- hatem0
Thanks, it working now.
I will post the full code for reference.
//Turn off built-in DOTSATR LED in Gemma M0 board.
#define NUMPIXELS 1
#define DATAPIN 3
#define CLOCKPIN 4
void setup()
strip.begin();
strip.show();
void loop()
- dastels
Excellent!
- cmj879
I want to turn off the DotStar on a Trinket M0. This code is not working. The program uploads, but the serial port disables. I checked the hardware with Blink and it works and the serial port remains. I'm running Windows 10 and have not installed Adafruit drivers. Just wanted to see if there is some other issue before I mess with the drivers:
#define NUMPIXELS 1 // Number of DotStar LEDs in strip
#define DATAPIN 7
#define CLOCKPIN 8
strip.begin();
strip.show(); // turn off the *%$*@ DotStar
- dastels
Does the dotstar turn off?
- XRAD
try this, avoids pin confusion....
Adafruit_DotStar dot = Adafruit_DotStar(1, INTERNAL_DS_DATA, INTERNAL_DS_CLK, DOTSTAR_BGR);
dot.begin();
dot.show();
