slide trinkey, rotary trinkey as IOS midi controller?
- pddoctor
Hello, I am wonderg if I can use a slide tinkey and a rotary trinkey as IOS midi controller. I am new to these and python programming. I purchased them with hopes they are recognized on iPAD as USB class compliant devices. in fact, they are not showing up. Is there any a programming library that I can install on these two devices? I just need to make them to send midi cc messages to IOS device like iPAD. Thank you so much. Best,
- johnpark
Re: slide trinkey, rotary trinkey as IOS midi controller?
Yes, those can work as USB MIDI controllers for iOS. Have you installed CircuitPython on them? Once you do, try this tutorial https://learn.adafruit.com/adafruit-sli ... ross-fader
- pddoctor
Thanks million. from the downloaded file, I was able to make a slide trinky into the midi controller working on IOS. It is amazing. but I still don't know how to make a rotary tinkey as midi controller. Can you uplode the file for rotary or direct me where I can find the code please ? Best,
