Proximity Trinkey board error
- ediener12
I have set up my board with ProxLight Trinkey M0 (SAMD21) but I am unable to upload and keep getting this error: Error compiling for board Adafruit ProxLight Trinkey M0 (SAMD21). Am I using the wrong board, is there something I can do to fix this problem?
- adafruit_support_carter
Re: Proximity Trinkey board error
It's a compilation error, so probably something code related. The actual error would be further up in the output, and you may need to turn on verbose output in the Arduino IDE to see it.
What is the complete code for the sketch being run?
- ediener12
The code is just the Proximity Trinkey Shipped Demo.
Thanks. Just did a test compile here and it worked OK.
Please turn on verbose output:
File -> Preferences
Show verbose output during: check [ ] compilation
Recompile the sketch and post the complete text of the error message here. There should be a button named "Copy error messages" that will show up in the lower output section of the Arduino IDE.
File -> Preferences
- ediener12
Ah it seems that my boards were not installed correctly, and I re-installed them and it uploaded correctly. Thank you.
