Using a Trinket M0 as alternative board for Genesis Poi: Dot
livingkurt
Post by livingkurt »
Hello! I just found out how cool the Trinket M0 is and I want to use it in everything now! Sorry I'm late.
I've had my eye on the "Genesis Poi: DotStar LED Persistence-of-Vision" build for a while now and I'm finally ready to do it.
Link: https://learn.adafruit.com/genesis-poi- ... i/overview
So I saw from the beginning that the Adafruit Trinket - Mini Microcontroller - 5V Logic was no longer supported in the newest version of the DotStar Library.
I then bought the Trinket M0 thinking it would work as a replacement.
That's not the case at least for me sadly...
I really want to use the Trinket M0 for this build, has anyone adapted the code to work with the Trinket M0 or have any insight on what isn't supported?
I'm getting this error right out of the gate
poi:40:10: fatal error: avr/power.h: No such file or directory
 #include <avr/power.h>
compilation terminated.
exit status 1
From what I've read this error is that avr/power.h is part of the standard arduino IDE install package and it is specific to certain avr processors.
So it feels like this feature doesn't exist on the Trinket M0, is that correct?
I am using the Adafruit SAMD Boards to choose from, and am choosing the Trinket M0.
I really really want to make this work.
Any info is helpful
Thanks for your time!
adafruit_support_mike
Re: Using a Trinket M0 as alternative board for Genesis Poi:
livingkurt wrote:From what I've read this error is that avr/power.h is part of the standard arduino IDE install package and it is specific to certain avr processors.
That's correct. The code is optimized for the original Trinket because the ATtiny85 doesn't have much memory. Making the code more portable would make the original Trinket version harder to use.
The code will require modification to work with the Trinket M0. The graphics code should be portable, but I'm not sure how well the code for the IR remote will work.
Break it down into smaller pieces and test them individually.
