Greetings all,
I am working on an LED lighting project using a Trinket M0 to control an ISSI LED driver IC. The LEDs will be on a board that is covered by a layer of diffusing plastic. What I'd like to do is be able to touch the cover plastic and toggle through LED sequences (rather than a button or sensor off to the side). TDK makes a conductive clear film that I thought could be used as a touch sensor. I was just curious if anyone had any experience in this type of thing or if anyone knows of a better way, because I'm a little outside my comfort zone on this one. Thanks!
Muscle Nerd Jerry
https://www.digikey.com/en/products/det ... -4/9634768
Touch sensor design
- mikeysklar
Re: Touch sensor design
That conductive plastic sounds like an interesting solution. Did you only want a single touch sensor input?
I normally use copper foil tape on acrylic for touch sensors inputs. You can make cool patterns and have many touch input controls.
https://www.adafruit.com/?q=copper+foil ... =BestMatch
- HeliconEnt
Sadly I can't use anything opaque, so copper is out. And yes, just a single input to toggle the LED sequences.
Jerry
Jerry
mikeysklar wrote:That conductive plastic sounds like an interesting solution. Did you only want a single touch sensor input?
- mikeysklar
"clear conductors" really are a fascinating topic. I see a lot of research discussion comes up on that topic and very little in obtainable form today.
Maybe touch sensor isn't the best option here. Could you mount the screen with a normal pushbutton behind so when pressure is applied it activates?
- adafruit2
you can use ITO for resistive/capacitive touch sensing
https://www.adafruit.com/product/1309
- HeliconEnt
Marvelous, this is exactly what I need!! Thanks so much!adafruit2 wrote:you can use ITO for resistive/capacitive touch sensing
Muscle Nerd Jerry
- HeliconEnt
One last question:adafruit2 wrote:you can use ITO for resistive/capacitive touch sensing
Software aside, is it as simple as a single lead between ITO and pin #3? I head of someone else using an additional resistor to reduce accidental triggers from static. But that was on the Tiny85 version of the Trinket.
Muscle Nerd Jerry
- adafruit2
treat it the same as any conductor - you'll need to experiement with your setup to figure out any resistors or wiring kit - it really differs each tme
